Question about Kenmore 43142 Front Load Washer
Front load washer doesnt switch to the next cycle.
The washer will do the first cycle but will not move on to the next one. if manually put it on the following cycle it will perform accordingly but still stop and not go to the next cycle. please help. Sears said they can come in but im sure it will be expensive
    Master:
  • 619 Answers
The timer motor does not turn need to replace .
Posted on Jan 09, 2008
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
My frontload gallery series washer will start cycle, but only continues to fill with water and drain. It did this all night but didn't go on to the next stage of the cycle...is it a bad control switch
Sounds like a problem with the main electronic control board in the control panel but the only way to know for sure is to do some electrical testing with a volt meter and the wiring diagram from the machine.
Click here for: How It Works: Front Load Washer
Repair Parts: RepairClinic.com
Nov 06, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer refuses to move to next cycle
Can you still open door when it has filled?If so it is intermittant door lock .If no new progame card required.
Nov 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Front load washder does not go through with cylce
hello nplooj
welcome,
You said, front load washer would not continue through the cycle. For example, when I turn on the wash cycle, it will stay at that position and does not go to the next cycle. Every time I want the machine to move from one cycle to the next I have to do it manually such as from wash cycle to rinse cycle. The dial won't not turn unless I turn it manually. Please give me a suggestion of what part of the machine is not working properly. Per my understand and my friend told me, it is probably the time is not working. If that is the problem, can I replace the timer myself and how much it cost for the replacement part.
You do have an ATF6000 front load washer?This is made by Frigidaire or Electrolux
Did you get any error code?
Like an "F1" ?
Yes it can be replaced It is part of the,
Control Board,pc ,with housing $ 139.22
Here is the site with the parts.
http://www.pcappliancerepair.com/model-display.php
Let me know how you do.
Huuum,
Please remember to leave a rating!
Oct 13, 2008 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire Tumble Action Washer won't move to the next cycle
your pump is blocked or faulty a way to check is pull your washer out put your outlet hose to the ground placed either in a bucket or out the door if water comes out pump is faulty if it doesnt than its blocked were your outlet pipe goes into back panel is were your pump is make sure washer is switched off undo tip up undo clamp water will come floding out better of doing this outside if it comes out of pump than your pipe is blocked
Aug 13, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Kenmore 43142 Front Load Washer Logo
51 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
