Question about HP PSC 2110 All-In-One InkJet Printer
Hp bs or ps 2100 series printer
What do I do when the computer says the ink cartridge is out of line.
  • richa2o Dec 13, 2007
    i want to downoad a software of this printer so can u tell me plz
  • 4,402 Answers
Posted on Dec 18, 2007
HP deskjet 6122 prints test page but everything else doesn't print
Regarding your recent inquiry about the HP 45/78 printer error condition (i.e. improper print quality, etc'), it sounds like your cartridge's internal micro-electronics are either clogged or have electrically failed and will need to be replaced. NOTE: The HP 45/78/78+ ink cartridges are extremely robust (compared to many of the newer versions found in market today) and can typically be refilled 8+ times, on average, before suffering a hard internal electronic failure. To verify the electrical health of the ink cartridge, please perform the diagnostic checks below or refer to our HP printer diagnostics document:
In some cases the ink cartridges just need to be FIRMLY re-seated into the carriage assembly (also check the cartridge restraining mechanism/arms if present - sometimes these mechanical restraints/arms become loose over time...please double-check these if applicable). We also suggest that you ensure the printer carriage/flex cables (where the cartridge interfaces to the carriage inside the printer) and ink cartridge rear electrical contacts are thoroughly clean to rule out poor connectivity as root cause:
Cartridge & Printer maintenance should be evaluated:
Ensure both ink cartridges and flex cable contact surfaces (where the cartridge interfaces to the carriage inside the printer) are thoroughly clean:
1) Gently blot the cartridge Nozzle Plate with a damp lint-free towel/wipe - a small amount of ink should be dispensed, and be visible, on the towel (all 3 colors should be present for a Tri-color cartridge).
2) If no ink is dispersed from nozzle plate (i.e. visible on towel) or ink cartridge completely fails to print on paper after installed in printer, then more drastic cartridge and printer cleaning steps will likely need to be performed to recover ink cartridge (NOTE: foam inside cartridge can dry out and become very hard - the foam must be moist with ink to function correctly (i.e. ink flows and wets the nozzle plate). Refer to 'clogged ink cartridge recovery' video here:
Providing the ink cartridges are clean, the problem may be caused by a dirty wiper blade or poor seal in the service station (capping station where the ink cartridges park when not in use) and this is causing the poor jetting / print performance issue you are observing. Remove the ink cartridges and thoroughly clean the wipers and seals:
DIAGNOSTIC TESTS FOR HP Officejet and LX, Officejet 300 series, 700 series, T series, D series, K series, G series, V series, 4100 series, 5100 series, 6100 series, 7100 series PRINTER (HP 45/78 ink cartridges):
Perform Self Test Print:
1. On the front panel of the product, press Menu (or Setup).
2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK.
3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged.
Perform Printer Error Reset:
1. Open the printer/cover as if replacing the cartridge and allow the carriage assembly to move to the cartridges access/loading position.
2. Unplug the power cable from the rear of printer and close the printer's cover.
3. While depressing the power button, plug in the power cable. Keep the power button pressed for about 10-15 seconds, allowing the error flag to reset.
4. After printer powers on, cycle printer power once again and allow printer to fully initialize (may take ~5 minutes for the message/error condition to disappear).
NOTE: If ink cartridge error persists then replace ink cartridge.
If procedure above does not work, then refer to to print a HP Self-Test Report (older HP printer models) - click here for instructions & sample prints:
*Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. Typically the ink cartridge's nozzle plate suffers a break at one of the flexible circuit lines within the base of the cartridge nozzle plate...refer to photo at bottom of this page:
However, if your printer works routinely after inserting a brand new HP 45 black or HP 78 color ink cartridge in it, this will confirm the root cause of failure.
We trust this detailed technical information provides you some additional insight into the issue you have endured.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
HP 45/78 Ink Refilling Services & Additional Cautions:
If you need to purchase a new ink cartridge, we suggest you try a remanufactured HP 45/78/78+ ink cartridge from as their ink cartridges typically have the lowest cost in the USA and reportedly have a high reliability rating (plus free shipping for all orders above $20).
For any additional questions please contact us directly:
-Thank you
Aug 30, 2014 | HP DeskJet 6122 InkJet Printer
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
Good luck
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video:
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site:
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video):
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
Installed a recycled ink cartridge for HP C4380 printer. Now it won't recognize the cartridge
We have a Photosmart C4700 series and we can only use recycled ink cartridges 2 or 3 times and then the printer rejects them. I don't know if this anwers your question at all.
Oct 28, 2010 | HP Photosmart C4400 series
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Oct 05, 2010 | Office Equipment & Supplies
We purchased a HP Photosmart C4400 series last December 2009. I have just put in a new black ink cartridge and the printer is not printing the black properly, it still very faded. I have put in the correct...
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Oct 04, 2010 | HP Photosmart C4400 series
How can I make your 8500 pro accept a refilled HP cartrige.
The HP 940 cartridge is the new version of the HP 88 cartridge. Both have a chip that estimates ink levels. Once the chip says the cartridge is empty it will refuse to print, no matter how much ink is really left in the cartridge. This is a safety measure so you don't get air in your ink lines. If you get air in an ink line, that color will no longer print. We can refill the HP 88 because there are replacement chips available for these cartridges. I own a Cartridge World ink refilling store and I don't refill the HP 940s yet because I don't have access to a replacement chip. If you purchased a refilled HP 940 and it's not working, I would say the chip has not been replaced. I would wait until a reputable refiller (i.e.-Cartridge World, Office Depot, etc..) offers refills for this cartridge before you try anything off the internet.
Feb 16, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
For using the HP Deskjet 5000 series Printer Assistant:
  1. Double-click the 5000 series printer assistant icon on the Desktop of the computer.
  2. Click Utilities .
  3. Click Printer Maintenance .
  4. Click Clean Cartridges .
  5. Follow the on-screen instructions.
read info on this HP link:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | HP DeskJet 5550 InkJet Printer
Where is the ink cartridge located on the hp psc 2110v all-in-one printer, scanner, copier
With the power turned on.
Just above the paper try & below the scanner bed.
Lift the edge till the hole top opends like a book. The carridge with ink cartridges will move to the center of the opening. Do you not have a manual? Download it at the link here.
Download the file that reads: HP PSC 2100 Series all-in-one - (English) Reference Guide . Start on page 26 for ink cartridge.
please vote...
Feb 18, 2008 | Computers & Internet
2175 printer
This is a typical error with the 2175 / 2100 series.
1.) Error comes up if ink in cartridge's ink level gets too low.
2.) The ink cartridge's copper contacts are dirty. Dirt you can't see. Clean contacts with alcohol & cotton swab's (not dripping).
3.) The carridge contact's need cleaning. (Same as above).
4.) The cartridge, (even though new, can be defective).
5.) You are using a "refill kit" of some kind to refill ink cartridge's.
6.) After 1-5, re-set the printer. Power off printer wait a minute & power back on.
Feb 11, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2110 All-In-One InkJet Printer Logo
Ben Johnson
