Question about Ricoh FAX5000L Plain Paper Laser
Ricoh Aficio fax 5000L (error code & Factory Settings?)
We purchased this machine used from a company going out of business. When I plug in the machien a red light comes on that says error code 3-31 call service. I downloaded the manual which simply says call a service repair location. Does anyone know this error code or how I may go about resetting the machine to factory settings? I have not yet located a service repair person in my area, Clayton Missouri.
Thanks!
  • imageusa Dec 16, 2008
    What unit? The fuser or laser scanner?
  • 417 Answers
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
Posted on Jan 06, 2008
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Aficio MP 2000
There should be a separate manual to cover the fax function in the machine. You can download one at Ricoh.com
Aug 04, 2017 | Ricoh Aficio CL7200DT2 Laser Printer
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Jan 29, 2009 | Ricoh Aficio 1035 Copier
Aficio 5000L will not receive most faxes.
That is a problem with your phone service. Your fax machine does not care where the fax comes from.
Dec 01, 2008 | Ricoh FAX5000L Plain Paper Laser
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
Could not receive and send Fax
Sending faxes and revieng faxeng through a pbx you need te configure the pbx and youre fax too.( Dail a 0 before youre messages! ) You have to connect always on the pstn line on the 210sf even if you use a pbx.
The Ricoh spc210sf isn't supporting an pbx on isdn line!! Watch out for this because the isdn line is working on 24Volts!! Then you can blow youre fax modem of the spc210sf .
You can contact me true email= r.trip@alice.nl
Let me know is you encounter new problems?
Greetz
Richard Trip
Jan 16, 2008 | Ricoh Aficio SPC210SF All-In-One Laser...
Error code 0-09
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
area
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
machines.
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Jan 04, 2008 | Ricoh FAX5000L Plain Paper Laser
Fax confirmation
check the settings in the paper tray. Do you have a manual? Should be info in it to change paper specs.
Aug 23, 2007 | Ricoh FAX5000L Plain Paper Laser
Ricoh Aficio 5000L Fax Printer-Adding names to Group name
On every fax i've worked on, you cannot edit groups. You have to delete the group and start over.
Apr 17, 2007 | Ricoh FAX5000L Plain Paper Laser
Ricoh FAX5000L Plain Paper Laser Logo
1,435 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
