Aiwa color tv 14" model a1419 is getting message
AFTER POWER CUTOFF WHEN POWER COMES AIWA 14" COLOR TV MODEL NO A1419 IS DISPLAYING THE BELOW MESSAGES SO HOW
TO DO THE SETTINGS AND HOW TO ENTER INTO THE SETTINGS AND HOW TO SAVE THE SETTINGS AND WHAT ARE THE EXACT VALUES
FOR EACH BELOW SETTINGS. PLEASE TELL ME THE RIGHT VALUES.
AGING
AFT IN
HEX 0104
DOWN 00
HIGH
HEX 0106
DOWN 00
0 CONT
1 COLOR
2 SHARPNESS
3 SUB CONTRAST
4 V LINEA
5 VS CORR
6 ABL START
7 IF FREQ
8 BGP P
9 PARABOLA
10 TRAPEZIUM
11 V EHT
12 CORNER
13 H EHT
14 H POS
15 V POS
16 OSD H
17 PIF VCO
18 RF AGC
19 R CUTOFF
20 G CUTOFF
21 B CUTOFF
22 G DRV GAIN
23 B DRV GAIN
24 BRIGHT
25 SECAM B-Y
26 SECAM R-Y
27 RGB CONT
28 H SIZE
29 V SIZE
30 TINT
31 TEST
32 TEST2
33 BRIGHT MIN
34 BRIGHT STEP
35 BRIGHT MAX
36 CONT MIN
37 CONT MAX
38 COLOR NTSC
39 COLOR MIN
40 COLOR SECAM
41 COLOR MAX
42 RG CONT MAX
43 SHARP MIN
44 SHARP MAX
45 SHARP NT
46 SHARP NT VIDEO
47 SHARP VIDEO
48 TINT MIN
49 TINT MAX
50 TXT RGB MAX
51 ABL GAIN
52 V AGC
53 WHITE PEAK
54 MUTE
55 AF GAIN
56 VIDEO POL
57 BPF/TOF
58 CHROMA TRAP
59 HALF TONE
60 COLOR SYSTEM
61 CW SW
62 AFT MUTE
63 BLUE BACK
64 DC NF
65 V FREQ
66 NTSC COMB
67 BLANKING
68 H OUT STOP
69 FORCED ID
70 SELF ADT
71 ID SENSITIVE
72 SECAM ADJ
73 AFT ON
74 YM EMB
75 YUV SW
76 AFC GAIN
77 V LINEA 60
78 H SIZE 60
79 PARABOLA 60
80 TRAPEZIUM 60
81 V EHT 60
82 CORNER 60
83 H EHT 60
84 VS CORR 60
85 V SIZE 60
86 V POS 60
87 H POS 60
88 OSD H
89 OSD V 60
90 G VSIZE
91 G HSIZE
92 G VSIZE SHIFT
93 G HPOS SHIFT
94 OSD V
95 FM MATRIX
96 VOL LOUD SPK
97 VOL FM/AM
98 VOL NICAM
99 PRESCALE SCART
100 PRESCALE IDL
101 NICAM IDH
  • ramarama Apr 28, 2009
    same problem
pfccrisgarci
SOURCE: sanyo 13 or 14 inch TV, C 03 shows on the screen, how to remove
i can't able to oscillate the horizontal output of sanyo tv model no. ST-14se1 tho power indicator keeps on blinking only what component should i consider to replaced?
Posted on Oct 26, 2009
SOURCE: problem in 14" videocon colour tv
whats the videocon portabel flat tv internal service mode code
Posted on Feb 12, 2010
  • 3 Answers
SOURCE: Haier HLT71-7'' LCD TV
ITS BROKEN
Posted on Mar 06, 2010
SOURCE: find the error, its impossible 1
The error is that 80% of people that could not find the solution that is 'impossible' to find means that 20% did, which of course is impossible; there is no solution to an error that is impossible to find.
It's a bit of a lame riddle really and disappointing when worked out.
Posted on Oct 22, 2010
SOURCE: Onida 14'' tv on screen showing blue line
ONIDA826 SUPPLYDO NOT PASSED FROM CAPACITOR TO STANDBY LED
Posted on Oct 11, 2011
I have Aiwa TV MODEL No. TV-A219. suddenly tv display is in center and it is only around 4 inch of display. what could be problem there ?
SMPS (Power supply regulator section circuit) problem. [Stamp like raster]. The output voltage from it is less than normal. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jan 11, 2016 | Aiwa Televison & Video
Osd is saying the main menu is locked how do i unlock
Win Tyler,
Information on resolving your locked screen on your LCD is listed below.
In the TV Menu Settings menu you can
select TV Button lock to lock the TV
Menu and the side panel buttons. When
this option is enabled, only the power
button functions. To unlock the TV Menu
and side panel buttons:
1. Press the Menu button on the TV. A message appears stating that the TV is locked
2. While the message is on the TV, press the channel up and volume increase button
simultaneously.
If you are using the DVI connector, you may need to verify the following settings:
Source - The default setting is Auto. The T V automatically detects if a computer (PC) or video
device is being used. If the image does not display correctly, you can select the source, PC or
Video, depending on the device you are using.
Color - The default color space is RGB. If the colors are not displaying correctly, you can change
the setting to YUV.
You can download and view the online users manual from the link below.
Manuals & documentation for your LCD TV W2306C
Product Support
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 18, 2015 | Dell W2306C 23 in. HD-Ready LCD Television
Tv error codes
This problem has been answerd a few while ago.
May 17, 2013 | Aiwa Televison & Video
What is the remote control code for techdisplay, model # 1910CB
093,018,094,087,099 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.
http://electrohelponline.blogspot.com/
May 08, 2013 | Aiwa VX-T1470 14 in. TV/VCR Combo
My aiwa tv a 219 remote locked how to open it.
Aiwa television comes with the option of blocking certain channels from viewing, allowing you to control which channels people using the television can view. However, if you forget the code that you entered to block the channels, you might find yourself unable to watch those channels. Fortunately, there are a couple of buttons on the television and the remote that you can press to reset the PIN and customer ID numbers, which unblocks the channels.
Turn the television on.
Press the "Volume Down" button on the front of the TV and press the "7" button on the remote at the same time.
Enter in a new PIN code and new customer ID.
Oct 30, 2012 | Aiwa Televison & Video
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
