Question about Refrigerators
Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
Just after a great Thanksiving our Refrigerators water dispenser stopped working so i figured must be time for new filter. I should have know that filter does not go bad overnight. Next morning I am getting fruit out of lower bin and the grapes are frozen. Odd, but I deduct that the water line coiled up in the back of food compartment is frozen if the grapes and celery have been. So I go to work buy a new water filter becuase it has been 9 months and when I get home the ice is melting along with the vanilla ice cream. So we lean out both compartments let the frost free? defrost.....clean it all up replace water filter, dispenser again works once line thaws out. Pray it was a fluke and turned it back on last night crossed my fingers to see if it would work again.
I woke up this morning after 10 hours of the empty refrigerator being back on and the water dispenser lines are frozen in back of ;lower food and compartment top of freezer not cold eough to freeze bowl of water in ice cream storage area.
It seems to me that the problem (I am a novice) may be in the fans and damper system between the two compartments? It is getting cold just in the bottom portions of the freezer and food compartments.
  • Trey97140 Nov 27, 2007
    So do you have step by step instuctions to do this repair? or point me in that ddirection.
    I know it is getting cold in the bottom area in both the freezer and food compartments as it froze the coiled water line in regrigerator but did not freeze the water in upper icemaking area in the freezer.
    Hoepfully it is not the compressor?
    I am thinking it is the fan that circulates air in and between the two compartments.
    Just don't know where to start and ball part on repair to cost?
    I have downloaded manuals and will read them.
    Thanks
  • Trey97140 Nov 28, 2007
    Thanks I have some things to check out when I get home tonight after work for sure.
    Sergeant:
    Champion:
  • 298 Answers
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Posted on Nov 27, 2007
  • 1 more comment
  • Eugene Merritt Nov 27, 2007
    Oops I'm sorry the defrost timer on this one is a circuit board
    # 241508001 A B C D Control-defrost, adaptive timer, PC board
    If you need any help get back to me
    Well if you want to start with the damper
    Item 115 in the parts manual contrrols section is the damper
    try adjuating that see if that help try & notice whether that
    defrost heater comies on you can here it popping when its on
    You can test the defrost timer thusly
    This product comes equipped with an Electronic Defrost
    Control. To initiate defrost, depress the fresh food light switch 5
    times in 6 seconds (light bulb must be working). To terminate
    defrost, depress the fresh food light switch 5 times in 6 seconds.
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
Ice cream is not freezing on FFUS2613L Frigidaire Refrigerator
Thanks for your post, friend!
I understand that your ice cream inside of your Frigidaire refrigerator, FFUS2613L. I would turn down your thermostat to see if that would help correct the issue of your ice cream not freezing. I hope this helps. -Matt
Sep 30, 2014 | Frigidaire FFUS2613L Side by Side...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Leaking side by side
You have to unclogh the drain hole inside the freezer at the bottom of the back wall by pouring hot water into it until ice melts and keep pouring to make sure water goes through .Repeat this every 3 o 4 months to keep it clear.
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Jan 27, 2009 | Frigidaire FRS20ZSG
Kitchenaid superba ice freezes in the bin
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
May 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Refrigerators Logo
665 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
