Question about Toshiba Televison & Video
Finding the channels link function which has now disappeared from the menu on my toshiba tv. the software download and install functions do not work and there is nothing else remotely relevant
SOURCE:
  • 275 Answers
SOURCE: Lost functionality w/ Universal Remote
Now, it depends upoon the Universal Remote u purchased. If your remote has the neccesary buttons - AV/TV switching,Front - Rear Input Switching, Menu, etc, it should work! Since there are multiple codes for every brand, keep feeding the various codes one by one, and checking if the neccesary functions operate. If, finally, you are unsuccesful, then, folow techman's advice. Best of Luck.
Posted on Jul 22, 2006
  • 4 Answers
SOURCE: Remote doesn't work
According to Mintek support you should unplug your set for 30 minutes which is a reset/rebooting process. Then plug it in and hold the DVD eject button for 5 seconds [at least]. The DVD should eject unless there is another problem. If it doesn't eject then call Mintek support at 877-646-8358 for help. They told me you have to send the TV to them and they'll send a new one. If you have to do that then make sure you tell them you want your DVD returned when they get it out. Good luck.
Posted on Mar 19, 2007
cammykins
  • 149 Answers
SOURCE: Toshiba CT-852
A universal remote would cure this problem. It's generally since they are on the same system or IR codes are similar. There isnt much you can do to fix that problem unless you have a seperate universal remote to opperate seperately.
Posted on Sep 24, 2007
Buschchris1
  • 474 Answers
SOURCE: Function keys not working
try holding down the function key and hitting the numlock or scroll lock key, this is usually how you engage or disengage the laptops function keys on the keyboard. Most laptops have a light that will turn on and off when you do this, indicationg that the funtion keys are in use. depends on the brand
Posted on Feb 17, 2008
SOURCE: toshiba CT-90275 remote
I have the same piece of junk remote and it has been slowly losing functionality over the last two months. Strangely enough, the only thing mine WILL do is scroll through the channels. Toshiba is about useless but if your TV is still under warranty, I'd call them and complain if this doesn't work. They are out of the remotes so plan on waiting awhile.
Turn off the TV and all the other things the remote is set up to control. Best to just leave that room altogether. Remove the batteries from the remote. Then, in turn, press each of the silicon buttons on the remote from top to bottom. Do NOT move the mode select switch at the bottom. Make sure you've hit each and every button. Replace the batteries and go try to see if it will work. Supposedly, this removes the static electric charges from the contacts under the buttons and will occasionally get the remote to work again. I had no luck at all. I've been waiting six weeks for a replacement and still no dice. The fastest way to fix the problem is to just go to an outside supplier and buy another one for $30. Then should Toshiba actually ever send you a replacement, you'll have one for the next time it crashes and burns.
I have a Toshiba 37HL67 model LCD and there is also supposed to be a firmware upgrade needed for those type models. The odds of that being the problem are so remote as to not be considered, but you never know. You will have to contact Toshiba to find the nearest repair dealer and have them do the upgrade. The upgrade is pretty simple. You unplug the TV, remove the cover for the card insert on the back of the TV, insert the firmware card. Replug the TV, follow the instructions on the screen, unplug the TV when it's done, remove the card, reset the little cover, plug in the TV and let it reboot. Toshiba guarantees that they will make the service guy come to you, but they usually are too lazy and want you to bring the TV to them. Toshiba will force them to do it, but if you can just get them to give you the firmware card you can download the instructions. Hope this helps.
Posted on Nov 18, 2008
I bought a Toshiba TV with remote CT90326 from a friend who had a different service (satellite) and I have cable and the remote works to turn on the TV , punch in specific channels, and to change volume,...
Any television remote will give full access to the television functions. The remote must be specific to that television. Google
make model replacement remote
There are original ones on ebay, plus companies that sell remotes that are an exact copy. The CT90326 may be for another Toshiba model, or of course it may be faulty.
Then we have the remote on the cable or satellite unit. That gives full command of the unit functions, but BASIC control of the television, normally On, Off, Channel Up and down to allow access to DVD or similar and Volume Up and Down. Everything else is done from the TV Remote.
To get the cable remote to make that happen, you Google
Toshiba Remote Codes
and run through them all until a selected code allows you to switch the television on and off.
Sep 25, 2017 | Toshiba Televison & Video
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
I lost my Original Toshiba remote control for my TV and I need to do a channel scan that is in the setup menu, but the TV itself doesn't have a setup button to push to access the scan function, How...
You can buy a universal remote, any best buy will carry one, I have even found cheap ones at dollar tree or dollarama. They come with a manual with the codes for the make of your TV just follow the coding instructions until you find the one that will operate your TV.
Good luck
Jan 19, 2018 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
We have just received a new toshiba 32BV500B LCD tv. We did the initial installation but after the analogue channel scan the digital channels have disappeared and we cant find a way to get them back. How...
Hopefully, if you were to press the menu button and somewhere on the screen will be DTV. Select DTV and then you can run search again.
Hope that makes sense.
Mar 11, 2011 | Toshiba Televison & Video
My remote no longer works and I can't get the menu to come up so that I can reprogram my channels and get all of my cable channels. Right now I only get basic cable channels, even though I have full...
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at retrevo.com in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
May 19, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Channel number does not go away
Press Display / Info button on "TV's Original Remote", on-screen display of channel number will disappear.
Dec 06, 2008 | Televison & Video
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Function switch doesn't work
This is due to switch malfunction problem. Dust and corrosions shows these type of problem. Make one general service by technical person. Or if you have keypad lock system in your menu options lock your keypad control. The TV will work.
Aug 28, 2007 | Toshiba 32A33 32" TV
Televison & Video Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
