SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
SOURCE: samsung washing machine p1253s showing
check the debris filter at the bottom right hand side of washer.
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
SOURCE: E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit
behind the port hole door frame ,where the door
striker pin goes through hole.hope this helps you.held on with 2 screws
and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
SOURCE: electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
