Question about RCA F27450 27" TV
TOSHIBA TELEVISION MODEL NUMBER 36ZD26P
WHEN I SWITCH T.V. ON, IT WILL STAY ON FOR 3 MINUTES AND THEN SHUT OFF TO STAND-BY, CAN YOU HELP ME, THANKS.
    Novelist:
    Champion:
  • 232 Answers
You most likely have some broken solder connections either in the low voltage area or in the horizontal section of the tv, board has to be removed and re-soldered, hope this helps
Posted on Nov 27, 2007
Goodman Furnace gms91155dxa not staying on. The system ignites, but shuts off after 3 minutes. 1 blink LED system light
100% sounds like an electrical problem, something is not allowing it to go into a duty cycle.
Dec 04, 2016 | Goodman Heating & Cooling
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
Will not stay on comes on one time for about 3-6 minutes then shuts down and will not come back on
It sounds to me like you may need to have your refridgerant checked as it could be shutting down on low pressre switch.Thank you.
Apr 17, 2011 | Heating & Cooling
2008 dodge ram 3500 brakelights will stay on after applied 3-4 times. will not shut off until 3-5 minutes after ignition is shut off???
Hi:
You most likely need a new brake light switch. It is located near the top of your brake pedal arm, and it is held in place with a pin and a clip, as well as a removeable electrical connector. They are not too expensive, less than $20, and relatively easy to change.
Hope this helps!
Oct 17, 2010 | Dodge Pickup Cars & Trucks
It starts with control set to max and it runs a couple of minutes and it stops so i turn the control to low and back to max it starts again and stops the same way the humidity is at 60+ so it should stay...
one of 3 possible problems,the control is faulty,you can bypass this with a jumper wire and see if it stays running, the condenser coil is dirty and is not cooling the compressor correctly and the condenser and evaporator coils need to be cleaned,i would do this first before bypassing the control,then possibly its low on refrigerant and the low pressure switch is shutting it down or the switch itself is faulty,please rate this if it helped you,thank you
May 30, 2010 | Goldstar DH304 Dehumidifier
Tv will not stay on only for 1 min. then turns red and off
Symptoms shows Red Tube is defective and needs replacement.
Please confirm model number with serial to look for Red Tube in stores.
Thank you.
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Toshiba television
Is it a Toshiba or RCA? What's the model number?? When it "stays on..." do you get a picture and audio okay??? If you continue turning it back on does the lapse in time continue to get longer????
Bill
Nov 27, 2007 | RCA F27450 27" TV
RCA F27450 27" TV Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
