Question about SanDisk Sansa e260 MP3 Player
My sansa e260 stopped working after unsuccessful formatting
I tried to format it several times and each time it was unsuccessful, it kept some unknown files which are not deletable. Then the last time I tried to format it, it didn't delete anything and when I try to play it, I can see the songs on screen, but all of them are 0:00 seconds long (meaning nothing) and don't play anything.
I appreciate your help!
Thank you.
  • ik20 Nov 29, 2007
    Dear Mixmaster,
    I did it the way you explained.
    First of all, the file I downloaded from rapidshare didn't work.
    So I downloaded the recovery tool from SanDisk website.
    Tehn when I put the device on hold and press "record" while connecting to PC, it says: "Welcome to Recovery Mode"
    USB cable connected.
    Enter USB2.0 MSD mode.
    Then some text file opens showing the product information.
    I've already installed the recovery tool, but no application opens, nothing is prompted.
    Any idea what I can do?
    Thank you very much.
  • ik20 Nov 29, 2007
    Thank you! Finally worked!
I have guys, I just spoke with the Sansa representative. Even if you have Windows Vista, you do not need a drive for e260 given that Vista carries that drivers for it. If you have tried the steps above, but you Sansa still did not format successfully after using the recoverty tool. This is what you do:
Set you Sansa e260 in recovery mode
- set it to hold
- hold rec
- connect to computer while you are holding rec
- device should be now in recovrey mode
- go to my computer
- go to the folder 16B format
- you will see a text file
- don't worry about
- add a new folder and name Sansa.fmt
- wait up to 2 minutes
- message on your device should say formatting
- wait a few minutes for formatting to take place
- stop the device by removing it safely using windows Safely device removal tool on bottom right corner of your screen
- disconneting your Sansa and you should see a message upgrade finished, Sansa has been restored or something like that
- Power your Sansa on, and Bwala!!! your Sansa is back to normal.
Good luck
Posted on Oct 07, 2008
  • 626 Answers
Try THis;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Posted on Nov 27, 2007
  • Timothy D
    Timothy D Nov 29, 2007
    As the instruction indicated, you are to RUN the software AFTER the device is connected in RECOVERY MODE.
    Run the tool AGAIN, select FORMAT.
    Best of Luck.
I've put the button on hold and pressed the rec button and plugged my sansa e260 back in and it say USB cable connected Enter USB2.0 MSD Mode, so I unplug it and it says Upgade finished Resetting the system and it still goes back to Load main image failed Switch to recovery mode. I've even downloaded the new sansa update and nothing, my media player won't read it either. I saw where they said to go to my computer click on 16mb-format and copy sansa fmt. to virson, I have not the slightest clue how to do this. Also does the e260 have to have a memory card in order for this to work?
Posted on Jul 07, 2009
I have question
i tried many times to put videos in my sandisk sansa
but it ain't working
what should i do
Posted on Feb 17, 2008
When I try to sync my Sansa e260, only a few of the songs actually get transferred to the Sansa from my computer. I've tried several times, and what is on the Sansa does not agree with what I have/had in...
Did you check the format supported by Sansa Player. If the format of your songs are not supporting by Sansa, try to convert those to compatible format and then sync .
Please let me know the result.
Nov 29, 2009 | SanDisk Sansa e260 MP3 Player
How do i put videos on my sansa e260 my computer says its not formatted or something
your sansa e 260 is not fomatted try to format it, just right click your sansa icon in my computer then click format, then check the quick format then click ok, after that it says format complet, now you can put videos in your sansa e260
Jul 01, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e250 won't connect
1.try formatting your sansa
2.try to copy again..
3.if it does not work tell me what sansa you are using
May 23, 2009 | SanDisk Sansa e260 MP3 Player
Formating problem
Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
Doesn't recognize some songs
change the format of these songs like the other ones.
Sep 28, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
It took me a few hours to crack these Sansa players, but with enough fiddling I have been able to recover many that were passed off as dead
May 10, 2008 | SanDisk Sansa e260 MP3 Player
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Unknown files and impossible to delete
First turn on the palyer and change the usb mode to MSC and when you connect it the the computer it should show up as a flashdrive type thing. right click on ita and select format make sure the when you format it it is going to be formatted to FAT32 type it will delete every thing on the player including those files you said couldnt be deleted
Jan 15, 2008 | SanDisk Sansa e260 MP3 Player
Blank Screen After Database tries to refresh
If you tried everything you could then Format the player. It will erase everything and will Very much fix anything wrong with the player. To do That go to start>my computer>Mp3's Drive. Probably a Letter like (F:) or (G:) which ever the mp3's drive is. Then Right Click on the Drive and Click Format. it will ask if you want to format, as it will erase everything. Click yes and perform a "quick format" when done. safely disconnect from the computer and restart. then load the songs. It should work then. Hoppe this worlks. :]
Jan 11, 2008 | SanDisk Sansa e260 MP3 Player
E260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
2,355 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
