Question about SanDisk Sansa e250 MP3 Player
Not showing video
Hi there, the problem I have w my e250 is that after a few days of use my videos disapperared, I explore the device, the video folder looks empty but the memory is down, as if the videos were there. I´ve tried everything I could, look for hidden files, update firmware, even formatting. I actually got the famous message: "Load image failed..." could not charge the unit.
¿What can I do?. Maybe i did not perform a good format, because I charged the rapsody file, and my model is not r.
Please help!
  • Diegox08 Nov 30, 2007
    Thanks, I´ve recovered my unit, replacing the pp5022mi4 file with this one:
    http://daniel.haxx.se/sansa/e200/PP5022....
    Now the problem that left is the memory remains low. What can I do to clean it up?
    Diego
    the recovery tool does not work with my unit
  • 626 Answers
Try This;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Posted on Nov 27, 2007
  • Timothy D
    Timothy D Nov 30, 2007
    The tool I sent you will format the device, removing all files.
    Otherwise, if it connects to the computer, you can format the device thru My Computer>Device Name (e200)>Right Click and selct FORMAT.
    Best of Luck.
I put videos and photos in my sansa e250 but they dont play
log off your I pod and start again after few minutes
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
My most recent videos will not open on my computer. It is the same memory card that showed just fine a few days ago. The previous recorded ones on the memory card still work fine on my computer. I can play...
In explorer - Under my computer/ devices - you will either have a list or details of files - the details under type will give you information of the file format - i.e videos may show as wmp, avi, etc
May 12, 2009 | JVC Everio GZ-MS100 Camcorder
I want to copy some video songs in sandisk sansa e250 but massage shows your device only support mp3/audio/folder files so what can i do?????
Use the Sansa Media Converter for video files - if you have lost your CD, download the program from Sandisk's website.
Mar 25, 2009 | SanDisk Sansa e250 MP3 Player
DELETING VIDEOS FROM MY MP3
Below are the instructions. I hope I've made them clear enough!
Make sure your device is under MSC instead of MTP...To do that go under Menu, settings and then usb mode...
Step 1
Open up Windows Explorer: Start > Programs > Accessories > Windows Explorer
Step 2
On the right of Windows Explorer, click on My Computer
Step 3
You should see two devices after your CDROM drive. One will be SANSA E260R and the other will be Sansa e200R Rhapsody. Chose the one on the top; the one that doesn't say Rhapsody. It may say E250R, E260R, E270R, or E280R depending on which model you have.
Step 4
Once you're viewing the device, you'll see the folders: PHOTO and VIDEO. These are the folders that contain your photos and videos. For videos, you can simply remove the video you want to delete - it will completely remove it.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Apr 26, 2008 | SanDisk Sansa e250 MP3 Player
DELETING VIDEOS FROM MP3
Step 1
Step 2
Step 3
Step 4
I hope that helps
Thank you
Computerrep
Audio and Video Not in Sync
You could try to use a different video converter to convert the files
Feb 29, 2008 | SanDisk Sansa e250 MP3 Player
Reg: Changing the modes of the device
You go to settings/usb mode, and change to MTP or MSC. If your settings don't show USB mode, you have to update to the latest firmware. If you have an E250, the video converter program will still probably not recognize the player. If you figure out how to get it to do so, please let us know.
Dan
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Will not recognise songs on player
Your Sansa E250 player comes in two modes -- MTP (Music Transfer Protocol) and MSC (Mass Storage Class). When you save songs on one of these modes, they would not be recognized by the other mode and vice versa. The reason for that is because the MTP mode is used for subscription music while the MSC mode is generally to allow your MP3 player to functions as a "Flash Drive", a regular mass storage device. To test if this is what's actually happening to your player, try each mode and see if you'll be able to "view" the songs when plugged in your computer: 1. Go to the modes on your E250 by navigating the player: Menu > Settings > USB Mode 2. When you've selected a mode, browse the player in your "Windows Explorer". Note: MTP mode will give you an icon of the E250 (player will be recognized as a Portable Audio Device) while MSC mode will have a Drive Letter (player will be recognized as a "Removable Drive") 3. Make sure that your Windows Explorer is configured to "Show all Hidden Files and Folders". To do this, access your Explorer's menu: Tools > Folder Options > "View" tab > enable "Show Hidden Files and Folders" You should be able to find the music files (or picture/video files for that matter) that have been taking up 1.4GB If you'd like to free up this 1.4GB, you may want to Format the player under MSC mode. To do that, right-click on the Drive Letter corresponding to your E250 in Windows Explorer, then select "Format". Follow the on-screen prompts and that should reset your player back to its original free space. Let me know if this helps. I may be able to offer some more solutions based on the result of the procedures above. Let's keep your Sansa E250 playin' :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
Videos have dissapeared, but memory still gone?
I had the same problem. I updated the firmware. I then set the unit to the MSC USB type. I then went to "My Computer" and right-clicked the drive and reformat in a fat 32. I now have all available memory back.
Jan 14, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
