Question about Zenith Televison & Video
My zenith DVD player works and sounds ok but why can’t I see my screen if the brightness is all the way up?
    Top Expert:
  • Zenith Master
  • 52,420 Answers
Screen failure
Posted on May 20, 2019
4 Suggested Answers
SOURCE:
SOURCE: no audio
i have the exact same problem.
Posted on Aug 22, 2008
SOURCE: Zenith dvb410 parental control
Without the DVD in the player go into your setup menu. Arrow down to the icon that is a lock press enter. arrow down to password and if it says new or change select it. you need to enter a pass code so that when the prompt comes up you can override the parental limits.
if you need to clear your old security code because you have forgotten it the manual says to input the 6 digit number from teh setup menu "210499" I did not do this as I had never set up a security code but the Across the universe DVD will play as long as enter the security code.
Posted on Sep 09, 2008
Gort007
  • 1187 Answers
SOURCE: screen will not stay bright
That's the battery saver feature of that Philips portable. If you use an A/C power adapter, the light will stay bright.
Hope this helps!
Posted on Sep 10, 2009
Screen will not stay bright
Hope this helps!
Sep 10, 2009 | Televison & Video
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
No image on screen
Definitely take it in. Not much room for error inside.
May 30, 2008 | Zenith DVP615 Portable DVD Player
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Movie is playing, but will dont display on screen
Try increasing the contrast. If that doesn't work, then make sure your input is on the correct setting. Press the input button and wait for a picture to load (about 5 seconds each) while trying to play a DVD. Also, make sure that the backlight is enabled. If you take it out into the sunlight and you are able to see a faint image of the movie on the screen, then you need to turn your backlight on. Most likely an option in the main menu, but it may also be caused by a broken sensor that senses when the player is closed and turns the backlight off, but also turns it back on when the player is opened.
Feb 11, 2008 | Zenith DVP615 Portable DVD Player
Zenith p42w24bx
u can buy tose on ebay set of 10 for 20 bucks gold bnc adpoters ok
Jan 31, 2008 | Zenith P42W24B 42 in. Plasma Television
No audio
Jan 08, 2008 | Zenith DVB312 DVD Player
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Televison & Video Logo
22 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
