Cell Phones Logo
How do I get my 9" digital 2 to come on when all it shows id digital 2 logo and that is even after. A factory reset. I dint want to have to do another reset.
1 Related Answer
Anonymous
  • Posted on Mar 18, 2012
SOURCE: how do i reset 2 factory default
If the Recovery Partition is still on the hard drive, you can restore to factory settings from it. pressing Ctrl-F11 while powering on should bring up the option ot recover. (the recovery partiion is put there by Dell for these situations. if it's not there, you'd need the original CD/DVD's it came with).If Ctrl-F11 doesn't work, try powering on while holding F10 or F12.
Cheers
2answers
I need to reset my phone amd i forgot my passcode
Hello Karabo, what kind of phone do you have?
If you're an iPhone user and forget your passcode, you will have to factory reset it without Apple ID. To do this you need first put the phone into DFU mode and connect it to iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Restoring iPhone to factory settings with this method will result in wiping all the data. The following steps will show you how to do that.
1. Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
2. After that, turn off you device. Press and hold the Home button for 3 seconds.
3. Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
4. When iTunes detects that your iPhone is in recovery mode, you can restore it now.
5. Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After factory resetting iPhone, you will get all the data swept from iPhone 6 Plus, and you can restore the files from your iPhone, iTunes backup or iCloud backup.
How to Restore iPhone 6 Plus to Factory Settings
Jan 19, 2017 • Cell Phones
tip
Factory Reset for Palm z22 handhelds
If you've set a password on your handheld, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. Under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
4.On your handheld, hold down the Power button.
5.While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
6.While still holding Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
on Mar 11, 2010 • Cell Phones
tip
Factory Reset for Palm TX handhelds
6.While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Bought a used iPod, it's a older one. And everytime I try to down load it wants previous owners email password. How do I change this to my own information?
You could factory reset the iPod but you will loose all data on it. Once the iPod comes back from reset and go through the configuration setup you can chose a new passcode.
Step 1 Press the Sleep/Wake button on the top of your iPod and press the Home button at the same time.
Step 2
Hold both buttons for 10 seconds.
Step 3
Release the buttons when you see the Apple logo appear on the display. Your iPod is now reset to its factory defaults and you will be guided through the initial setup process. After resetting your iPod, you'll need to sign in using your Apple ID and set up iCloud usage.
tip
Factory Reset for Treo 650 smartphone
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the palmOne or Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
I turned my phone on. It showed the Kyocera logo, acted like it wanted to go to the Cricket Wireless screen but Kyocera logo came back up. Will not go pass this screen. I have even taken my battery out and...
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
try this reset procedure ..and see if ti works..remember that you will loose any user data on it ..this will reset it to factory settings ..
Also it may be a good idea to remove any media on it ..
If this is not working ..you should get to the manufacturer support site ..and download the firmware and make an update ..or ..I would go for the original firmware and make a re-soft ..
I have recently purchased the Garmin nuvi 765T and I have charged it and waited to use in the car but after a few seconds of turning it on, it turns itself off after showing the "Garmin" company...
Try to soft reset it by holding the power button for at least 20 seconds till it restarts.
If that doesn't help - try a master reset to factory defaults by holding the lower right corner during startup for at least 20 seconds. This will erase all user data and starts the Garmin in factory default.
If it restart I suggest updating the software to the latest version on Garmin.com
How to i get it unlocked
You need to reset it:-
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Start up only shows creative logo
hmm.. it's stuck on that?
try pressing the reset button (usually on the back), to hardware reset it to the factory defaults. if that doesn't work, it's time to either call the manufacturer or extended warranty provider (if it's still under one), or give it a proper funeral :~)
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
