Question about RCA Televison & Video
Using the RCA RCR414BHE Universal remote, how can you cut off the TV and CAB/SAT at the same time?
    Habit-Forming:
    New Friend:
  • 74 Answers
The only remotes that turns everything off are satellite remotes.
(Dish Network, Direct TV, Shaw, and Bell)
Posted on May 19, 2019
SOURCE:
SOURCE: Using an RCA universal remote
WIKIPEDIA has this link for your situation: How to Program an RCA Universal Remote Without a "Code Search" Button http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button I think that should help with your situation. Let me know if it does not.
Posted on Aug 23, 2007
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
SOURCE: philips universal remote #cl035a need rca tv, dir tv sat codes
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
I hope that this link helps you!!!.. Your Welcome.. I had the same issue.. tried this and hey! it worked.
Posted on Aug 13, 2009
  • 109 Answers
SOURCE: Have an Aveis TV and an RCA universal remote. Need
There is no code for the Aveis Tv in the code list but you can try doing this for code search...
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Posted on Jun 04, 2010
Testimonial: "Quick response and helpful"
Dont know to change channel for cable
If you have a universal remote it will have a button with CAB on it or TV, SAT, CAB, DTV,. Toshiba remote may only run the equipment it came with. Try using a universal remote that will work everything you have.
Aug 13, 2013 | Toshiba Televison & Video
Unable to find a code for an admiral tv NO.GOJ
Most universal remotes work the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 23, 2009 | RCA 3-Device Universal Remote
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
New RCA RC246 remote with new RCA L40FHD41 TV. Dish remote won't adjust volume. Any ideas?
The Philips Universal Remote SRU4208WM/17 works with this TV. Must use the code learning feature.
Jul 12, 2009 | Universal Remote Control DIRECTV Universal...
Direct tv on universal remote
For this type of problem you will need to call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for assistance with your problem. Thank you for using FixYa and have a nice day!
Apr 04, 2009 | RCA 3-Device Universal Remote with...
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
Nov 17, 2008 | RCA Universal Remote Control
RCA Universal Remote Code
Here are the codes for Philips. If these do not work you have to use the code search feature.
Philips........002,006,007,010,011,013,016, 033,035,037,038,043,066,073
100 times).
for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-7.
Nov 12, 2008 | RCA Universal Remote Control
NEED HELP PROGRAMING UNIVERSAL REMOTE CONTROL
rca d770 universal remote how do i program
Sep 03, 2008 | RCA Universal Remote Control
Televison & Video Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
