Question about LG Televison & Video
My LG plasma TV has stopped working and is making a weird smell and a noise and not displaying anything the model is 50PB2DR-AC
  • Bai Wagner
    Bai Wagner May 19, 2019
    Its not the update I can't see any thing
    Habit-Forming:
    New Friend:
  • 74 Answers
A bad smell is a blown capacitor (most likely on the power broad)
Take the back off and look for bulged or leaky capacitor, and swap it out.
Posted on May 19, 2019
SOURCE:
fieldy14
  • 456 Answers
SOURCE: LG Plasma 42pc3d turns on, pops, turns off
Its very likely that you need to have LG perform a sodtware upgrade on your unit. Contact LG and see if your tv is one of the applicable units with software upgrade issues, please let me know if it works. Good Luck.
Posted on Dec 03, 2009
drivememad97
  • 5 Answers
SOURCE: 50 inch LG plasma tv,model #50PG20,makes a crackling noise and shuts off and wont turn back on
capasitor bad, go to youtube and type in plasma tvs. there is a video that shows u step by step how to change and how to identify bad capasator
Posted on Feb 25, 2012
SOURCE: Plasma TV smell?
i had the same prob and thought it would burn off. It didn't after a month. Read the comments and tried the plug direct into wall socket plus i washed off the tv surface several times. Now no smell. Not sure which action cured the problem but i'm now happy. It was so bad i had to leave a window open and at times i would gag from the smell.
Posted on Jun 17, 2010
SOURCE: Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
Posted on Mar 01, 2009
Slinteriors
  • 8617 Answers
SOURCE: RCA HD52W59 HDTV.....will not turn on, makes a weird noise
you need a new flyback. Its a very easy repair you need flyback 259296 and you can get a new replacement at the following link and they explain step by step how to replace it. Heres the link
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
No inputs working
possible mainboard isn't fuctioning right try reseting the tv from the menu to factory setting and trying again
Jul 14, 2014 | LG 42PG20 42 in. Plasma HDTV
TV TURNS ON BUT NO DISPLAY AT ALL.
do a reset by manually holding down the power button, sometimes that works
Jan 28, 2014 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Free tv repair advice
The noise you hear must be from its back-light inverter board. The ferrite core in the inverter transformer may make a high whistling noise and will be annoying. Contact any technician. It can be stopped by gluing. But is a skilled work.
Apr 23, 2013 | LG 60PV450 60-Inch 1080p Plasma HDTV
LG 50PB2DR won'tr recognize RCA L8H HD Media Player
a suggestion would be contact LG to inquire about a possible software upgrade being available for this issue.
Apr 03, 2012 | LG Televison & Video
Feb 25, 2012 | LG 50PG20 50 in. Plasma HDTV
LG Plasma 42pc3d turns on, pops, then turns off
The first thing you should look into is the Z-SUS board, the one situated on the right side viewed from the rear. This board develops a high voltage during operation that might be the source of the popping sound. It is also responsible in refreshing the panel for proper picture display. The weird colors on your TV indicates a faulty Z-SUS board.
Note: Unplug the TV and wait for at least five minutes in order to allow the voltages to drain before you disconnect or reconnect any connector.
  • Disconnect the Z-SUS board from the Y-SUS board. The Z-SUS board is situated on the right side viewed from the rear of the TV while the Y-SUS is on the left.
  • Plug the TV back and turn it on.
  • You will still be able to see the weird colors the moment the TV shut off but do not flash. If it does not pop and stays on and there's a sound, you are pretty sure the Z-SUS board is faulty. Replace it.
  • If it still pops and shuts off, disconnect the Y-SUS board from the power supply. The Y-SUS board also develops a high voltage during operation. The power supply is the one right between the Z and Y-SUS boards.
  • Re-apply AC power then turn the TV on.
  • You'll not be able to see any color or video. If it does not pop and stays on with sound, you have a faulty Y-SUS board, replace it.
  • If it still pops and shuts off, please let me know.
Feel free to update me of the result and your own findings.
Dec 03, 2009 | LG 42PC3D 42 in. Plasma Television
Dec 02, 2009 | LG 42PC3D 42 in. Plasma Television
MY lg plasma tv has very small white dot in the background. IS there a fix for this?
I THINK ITS A DEAD PIXEL , YOU CAN'T DO ANYTHING WITH YOU DISPLAY , CHANGE THE PLASMA DISPLAY COST YOU MORE THAN HALF OF THE TV
Oct 06, 2009 | LG 50PX5D 50 in. Plasma HDTV
Vertical lines on LG 50PB2DR
You need to replace the control board
May 22, 2009 | LG 50PX1D 50 in. Plasma Television
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Televison & Video Logo
19 people viewed this question
RONALD CARTER JR
