Question about The Computers & Internet
Chuwi laptop lid disables usb port when closed. I'm using an external monitor and keyboard/mouse. Need to be able to close the laptop lid and keep the usb ports alive.
    New Friend:
    Problem Solver:
  • 16 Answers
Go into power saver setting advanced and disable the USB sleep setting
Posted on May 20, 2019
3 Suggested Answers
SOURCE:
gotgeek2
  • 565 Answers
SOURCE: How can I "Keep Alive" the video out put to an
If you have Windows 7, click the start button and select Control Panel, then select "power options". In the left margin select "change when the computer sleeps". In the next box select "change advanced power settings". In the advanced power options box look for "power button and lid" and click the plus box next to it and change your settings. Make sure to click "apply" after changing the settings or it won't take.
Xp and Vista will be similar. In all cases you want to go into Control Panel and select power options.
Posted on Jun 06, 2011
ed_coyle
  • 104 Answers
SOURCE: I want to use a external monitor keyboard mouse and close the lid and keep working on the computer
There is a setting somewhere in control panel that should be set to... when lid is closed..."do nothing".
This should be in the power settings. The other options are "shut down", "sleep" or "hibernate".
Posted on Feb 01, 2019
I'm not sure if you'll be able to close the lid because you might need a laptop that is designed to work with a docking station to do that.
Anyway, you can hook an external monitor, usb keyboard, and usb mouse to the laptop and continue working as usual.
May 07, 2012 | Computers & Internet
Windows won't start at bootup. Instead the fan turns on.
It sounds like your operating system has failed. Your best bet would be to use a working computer to burn a new install disc / backup disc / repair disc and then reinstall your operating system, or if possible repair it.
Have you tried plugging the VGA output into an external monitor and turning it on? Maybe your screen has just failed, if it does output to an external monitor.
You can get it into external mode if you boot it up with an external monitor connected, a USB mouse connected, and a USB keyboard. Boot up the machine (plugged in!) and close the lid right away, and it should automatically kick over. If not, try windows key and P at the same time, once the machine is "running"
Aug 14, 2011 | HP Compaq 2530p (KS094UA) PC Notebook
I have a Dell Vostro and would like to lock the laptop and use a monitor and wireless keyboard whilst at home. Can you tell me if and how I can do this?
This is assuming you are using Windows 7. (Since you didn't specify. -_-)
Software lock at same time = No. Hardware lock at same time = Yes.
When you have the keyboard connect and the laptop plugged into the monitor, go to your Windows Mobility Center. Go to "Power Options. Look for "What to do when you close the lid." and tell it to do "Nothing".
Then close your laptop and lock it.
Viola.
Mar 24, 2011 | Dell VOSTRO 3500 Notebook
I connected my LG 22LD350 to my hard drive, and both the sound and picture work, after I selected "RGB-PC" on the monitor. But I don't see a connection anywhere on the TV for my keyboard and...
Hi bpollen,
you will use the computer for {GUI} Graphics User Interface!
The TV is a "secondary visual device, or monitor"
The TV "cannot give instructions or commands."
"You not be able to "tranfer information from the TV.
You will use the "Computer for [Input and Output] transmissions.
The "Keyboard and Mouse" stay 'connected to the computer!"
You will "control all functions for the TV; by using the computer."
"I hope this information solved some issues?"
!"Take a moment to rate the help."
Thank you! paul7of9
Mar 18, 2011 | Computers & Internet
Can i close my laptop while using other mouse and keyboard
I am assuming you mean the laptop screen, not power off. The other mouse and keyboard is an external mouse and keyboard connected to your laptop. either way .. the answer is use.
Just keep in mind what your settings our when you do close the screen lid as this will either place the computer into sleep mode or power off.
Oct 08, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
While at home I plug a wide screen monitor into my Dell studio 1737 Laptop. As long as I keep my lid open the icons and print on my monitor are the right size. When I close the lid, icons and prints get...
You appear to be cloning your internal LCD and as long as it is active, the resolution setting for the LCD is also controlling the resolution of the external monitor. When the LCD is closed, then the default resolution of the external monitor is being used by Windows 7 (It apparently has autodetected the size of the monitor and knows the Highest optimal resolution it will display.) The higher the resolution, then smaller the icons.
To resolve, go to display properties and check the resolution of the internal LCD and then set the External display to the lower resolution.
You should be able to wake the system with an external keyboard, by pressing the spacebar, if the system is sleeping
Jul 24, 2010 | Dell Studio 1737 Laptop
I have an Aspire 6930. The screen has become damaged when something fell on it during an airline flight. The lap Top works OK when hooked up to an external screen, Is there any way to remove the damaged...
It is not that much practically easy to remove the damaged screen including the lid. Instead, you can get an external mouse and keyboard, connect it your laptop and can use them while keeping your laptop lid closed. For this you need to hook up your external display and in the control panel -> power options, by default the settings will be there to put your computer into sleep mode when the lid is closed. You have to change this option such that when lid is closed nothing should be done.
I hope the provided solution is useful to you.
Thanks
Mar 30, 2010 | Acer Aspire 6930-6455 Notebook
How to block VGA port on my laptop
in most cases, you can switch between display modes by using the function keys. the keys from F1 to F12 on your keyboard should contain various symbols (sometimes in blue). one of those symbols looks like the front of a monitor (on some laptops it says "LCD/CRT"). look for the key with the monitor symbol (or the text "LCD/CRT"), press and hold the Fn-key on the bottom line of your keyboard and then press the display mode function key. then you will see if the image on your display switch from one screen to the other.
if you cannot find such a key, you can disable the external display by right-clicking your desktop and choosing properties from the drop-down menu. on the "settings"-tab you should be able to see two virtual displays. click on display 2 and then uncheck the box that says "extend my windows desktop onto this monitor".
May 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Using the laptop w/o an docking station
go to control panel>power options>choose what closing the lid does.... in this screen Choose the option that says DO nothing. This will allow you to close the lid and still work of the externals.
Nov 13, 2008 | HP Compaq Presario V2000 Notebook
I want to connect a Ultrasharp 1907 FPt monitor to my Dell inspiron. I have a power cable and also one from monitor to lappy, do I need a driver?
to toggle the screen between your laptop and the dell 19" monitor. Hold down the Fn key on the laptop and tap the F8 key. The screen would move to the external display.
There are three settings that can be done by the Fn + F8 key combination
1. Both the laptop and external monitor works
2. Only the external monitor would work
3. Only the laptop screen works
Thanks
Proton
Nov 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
