Question about Dodge 2004 Stratus SXT
Thermostat housing on 2004 dodge stratus sxt 2.7 sedan,how do I change it and find the location
Having trouble locating and getting to thermostat
SOURCE:
emissionwiz
  • 84966 Answers
SOURCE: 2004 Dodge Stratus 2.7 thermostat location
Finding the thermostat: Follow the LOWER radiator hose to where it meets the engine. It's in there. Most cars that I've worked on have the thermostat at the end of the upper radiator hose, but not this car. Replacing the thermostat: You need to remove the thermostat housing. (It's the piece that the lower radiator hose connects to.) - You do not need to remove the radiator hose from the housing. - First remove the bolt that is holding a bracket. This bracket just holds some wires in place. - Now remove the three bolts that hold the housing to the engine block. These bolts can be fairly hard to turn, but just keep trying. - Gently pry the housing away from the engine block. You can use a flat-head screwdriver to help pry, but do not scratch the mating surfaces of the housing and the block. - Pull out the thermostat, noting that the spring end goes into the engine. - When you put the new thermostat in, you probably want to use a new black rubber gasket, but you might be able to use the old one if you have no choice. Also, I didn't add any permatex or anything and it seems fine. - I tightened the bolts to 22foot pounds, but this might be a little high. Whatever you do, DO NOT overtighten the bolts. Couple other notes: I first removed the air cleaner cover and tubes to get a little more working room. I also unplugged one wiring harness to make more room. Otherwise, I was able to get my big hands in there. A new thermostat did not fix my problem. Here is a description of the problem I was having and the solution: Problem: The temperature gauge was spiking occasionally, all the way into the red. It would spike up and come back to normal. It would spike usually while in idle, but sometimes while driving. Usually about once every twenty minutes. Things I checked first: - The plastic reservior for the radiator was full to the top. - The electric fans were running, and running on high speed. - The car had working heat. - Replaced the thermostat. Did nothing to help the problem. Problem Found: - Vapor lock. Even though the reservior was full of fluid, it had previously gotten too low and the system sucked in some air. Once that happens, it doesn't matter if the reservior is full, the cooling system will not draw in the coolant. This is because filling the plastic reservior does not pour coolant directly into the cooling system. The coolant is sucked into the cooling system through a tube, like drinking soda through a straw. So the reservior, where they tell you to add coolant, was full but the cooling system (radiator, engine, pump, etc.) was almost out of coolant and wasn't able to draw in any more. Solution: When the engine is cool, open the metal radiator cap that's sticking right up out of the engine. It can be found by following the upper radiator hose to the engine. There is a tall metal tube with a metal cap on it. Pull that cap off (when it not hot) and fill it up with radiator fluid. (I use radiator fluid that's pre-diluted and designed for all makes and models of cars). Idle the car, in park, for about thirty seconds. Stop the engine and put the cap back on. If you're lucky, all the air bubbles are out of the system and you're all set.
Posted on Dec 02, 2008
SOURCE: changing thermostat on 2004 dodge stratus
my car just cut off and wont start back
Posted on Dec 18, 2008
ewashmidas
  • 362 Answers
SOURCE: Cant find transmission filter on 2003 Dodge stratus Coupe.
The filter is inside the transmission. You need to take the pan off the bottom then you can replace the filter and the pan gasket.
Posted on Mar 04, 2009
polarcycle
  • 1392 Answers
SOURCE: 2004 DODGE STRATUS 2.7L, Location of Crankshaft Position Sensor?
it is located on the right side of the motor, in the trans area. Actually in the bell housing.
Posted on Jun 23, 2009
  • 495 Answers
SOURCE: changing thermostat in 2004 Rendezvous
The dealership will charge around $450 to change the thermostat on the 3.4L engine.
You have to remove the crossover exhaust manifold. Once that is out of the way, the thermostat itself is easy. Before the manifold is removed, I could only touch one of the two bolts holding the thermostat housing in place, much less get a wrench on it.
If your engine is the 3.4L then the instructions below will work:
REMOVAL: - Remove the air cleaner and duct assembly. - Drain the coolant until the coolant level is below the thermostat. - Remove the crossover exhaust pipe. - Remove the radiator hose from the thermostat housing. - Remove the thermostat housing bolts and clean any sealer from the bolt threads.
(IMAGE: Removing the housing bolts) 725f95f.jpg
- Remove the thermostat housing and gasket. - Remove the thermostat. - Clean the mating surfaces.
(IMAGE: The removal and installation of the thermostat) 0b61938.jpg
INSTALLATION: - Install the thermostat.Install the thermostat housing and gasket.
NOTE: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
- Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm). - Install the radiator hose to the thermostat housing.Install the crossover exhaust pipe. - Install the air cleaner and duct assembly. - Fill the cooling system.
Hope this helps, happy holidays :)
Posted on Dec 22, 2009
Why is the cooling fan on engine running when engine is cold?
That would be a TEXT-BOOK definition of a MALFUNCTION = broken (needs fixin'.)
The fan motor in your car is thermally switched... just like the heater in your house...
It should "CLOSE" (to start the fan)
WHEN IT REACHES operate temp... and "OPEN" (switch off) when it has your coolant at an ideal operating temperature.
a GOOD start on this trouble would be to have your local auto-parts retailer look up "radiator thermostat" to get a good idea if we are talking about more than one.
(get a back-up price from an on line retailer... (I like rockauto)).
The best idea would be to get the specific schematic and check it for the number & location of that (those) puppy(s)... REPLACE IT...
and tag the OLD ONE with the FAILURE and CHANGE DATE...
If your trouble goes away you had an internal failure... that shorted your thermostat... IF it did NOT FIX THE trouble... you either HAVE ANOTHER thermostat or an EXTERNAL SHORT (in your wiring) yet to find.
Good luck... and happy hunting!
Nov 30, 2015 | Cars & Trucks
I'm having trouble locating the thermostat
It should be in the thermostat housing where the upper radiator hose connects to the cyl head.
Sep 19, 2012 | 1990 Plymouth Horizon
Having trouble locating thermostat housing?
Follow the top radiator hose back to the engine at the end of hose will be the thermostat housing.The thermostat will be under the housing.Should be 2 bolts mounting it to the engine.
Aug 10, 2011 | 1998 Chevrolet Blazer
Location of the thermostat in a 1997 chevy luminia 3.1 liter?
Click for zoom...
Fig. 1: The thermostat is located in the lower radiator hose on the 2.2L engine
Fig.: Separate the housing halves to access the thermostat
Hope helps (remember rated this).
Jun 01, 2010 | 1997 Chevrolet Cavalier
Where is the thermostat located on a 1977 cadillac coup deville?
its under where the top raidiator hose connects to the engine 2 bolts 1 bracket and take the top hose off
Jan 21, 2010 | 1976 Cadillac Deville
1986 grand national thermostat location
Follow the upper rad hose to the intake, remove the hold down and the
steel fitting.
the Thermostat is behind that.
Make sure you Lube the new O ring in the fitting or you will have trouble getting it back in.
Jan 07, 2010 | Buick Grand National Cars & Trucks
Where is the location of the thermostat in the engine of a 2002 grand am?
The thermostat is located under the air intake pipe, mind you it is kidda difficult to replace as I had a little trouble repacing it myself. You need to detatch the air pipe from the throttle body and the air box to get at it. Hope this answered you question, Im a previous grand am owner.
Aug 21, 2009 | 2002 Pontiac Grand Am
I cannot find themostat on 1994 mazda 626 2.5liter v6 engine
The thermostat is located on the front left of the motor facing the radiator(Almost directly below the radiator cap). The lower radiator hose is attached to the thermostat housing.
Mar 21, 2009 | 1994 Mazda 626
Dodge 2004 Stratus SXT Logo
Top Dodge Computers & Internet Experts
D. E. Hev
gbob59
Marvin
Marvin
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
