Question about The Computers & Internet
Can I turn off the automatic transitions when playing a slideshow on my Onn TV?
My DVD Slideshow will only play on my PC.
To play on a dvd player the files must have an extension the dvd player understands i.e. .avi, .mpg4, .mvk etc.
May 17, 2016 | Computers & Internet
Tip
Embed the imovie slideshow in web with video to flash converter for mac
Want to transform your interesting photos into entertaining photo show? Would like to create an elegant picture slideshow of a recent wedding party? Or capture the excitement of the birthday party to share on your blog? Or create a commercial presentation with photos on your homepage to promote your business? However, you don't know which software can help you to make a customiz picture slideshow.
If you are a mac user, I recommend you to use imovie which is free and powerful. Although designed primarily to capture and edit digital video, imovie also has the ability to import still images and employ professional-looking transitions like wipes and dissolves, add audio and text narration, and lay down a soundtrack that works in conjunction with the photos. By making full use of this feature, we can build a video with static photos.
Step1. Collect Photos and launch iMovie
Select photos you would like to add to your slideshow and click "iMovie" icon to open iMovie.
Step2. Create a new project
Right click on the Project Library, choose "New Project" in the menu. And input Project Name and select your favorite slideshow Theme. Hit "Create".
Step3. Import photos
Drag all collected photos into your iMovie window. Place them in the order you want them to appear.
Step4. Add effects to your photos
You can add music, text and transition to photo slideshow.
Step5. Export iMovie slideshow
Right click and choose "Export movie", select some parameters according to your requirement. Finally, you will find the exported movie is in M4V formats.
FLV is one of the most popular video files found on the internet. Therefore, when you finish your imovie slideshow and want put them to your site or get a bundle of M4V video clips to insert in your blog, you have to convert M4V to FLV with M4V to flash converter for mac.
on Jun 17, 2010 | Computers & Internet
Tip
How to make a Media center Shortcut.
Windows 7 Media center have multiple switches for customization.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen Examples: %windir%\ehome\ehshell.exe "/mcesuperbar://tv?live=true" – That will start Media Center in LiveTV mode
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK.
For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
on Feb 10, 2010 | Computers & Internet
How do you make a disk of pictures whiling playing music
Beth
You didn't specify what OS you are using.
If it's OSX then it's easy using iTunes & iPhoto to select a group of photos and background music.
My slide show on my MacBook gets transferred to the Apple TV automatically and shows up on my Plasma 50" Screen.
Cheers
Feb 17, 2015 | Computers & Internet
How do i turn on the media center buttons?
Simply add the switches you wish Media Center to start with and hit OK. For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
Hope this helps.
Feb 10, 2010 | Gateway M-6866 15.4" Widescreen Laptop...
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Magix CD & DVD slideshow transition errors
Try to reinstall the problem or repair it. Maybe it works, but if not, it maybe not ba compatible to your Operating System or you got a fake serial number. If it is it, try to call your dealer so it can fix your problem.
Feb 25, 2008 | Computers & Internet
Advanced Slide Show Functions
The IR-500 has an automatic slideshow function that provides continuous playback of stored images. A total of 9 transition effects are offered, including Normal, Scroll, Fade, Zoom Down and Random.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Computers & Internet Logo
18 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
