Question about Whirlpool Dryers
Whirlpool Cabrio Dryer WED5500X - Just need pointers on how to access the belt and pulley to figure out why it won't tumble.
SOURCE:
SOURCE: whirlpool cabrio dryer belt falls off after install
If you're turning the drum backwards the belt will fall off. Make sure you're turning the same direction the motor will spin it.
Posted on Jan 13, 2010
  • 4 Answers
SOURCE: Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Posted on Apr 17, 2010
  • 523 Answers
SOURCE: Whirlpool cabrio gas dryer does not turn gas on to
first change the ignightor if its a glow plug
Posted on Jul 01, 2010
SOURCE: have to replace broken belt on a whirlpool awz
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Posted on Sep 30, 2010
SOURCE: whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Posted on Jan 01, 2011
Front door willnot stay closed
Hello Shirelle,
The door lock mechanism is defective Or the door seal is seating properly.
Jul 04, 2015 | Whirlpool Cabrio WED5500X 27" Front-Load...
Got heat just no tumble belt is on
Try holding the door switch and having someone start the dryer. If you spin the drum by hand with the door open and it takes off spinning, you have a bad/jammed motor. 300-400 dollar repair someone else would be better off doing. 4 hours to figure it out. 130 dollar part on the internet.
Nov 26, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My cabrio dryer wed7600xwo is no longer drying right, I have to run loads 3 times to get them dry. What could the problem be?
This dryer has 2 belts. A smaller belt operates the blower. The nut tends to back out and the small belt falls off. Here is the result:
Bravos dryer innards of a failed blower belt
Look around on my foggy site for your service manual. Let me know
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 22, 2013 | Whirlpool Cabrio WED7600XW Electric Dryer
Have to replace broken belt on a whirlpool awz 7813 tumble dryer and wondered what way the belt runs around tensioners
Sep 30, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
Jan 09, 2010 | Whirlpool Dryers
Dryer does not want to tumble
Felicia
make sure to see if the blower runs free
in this case is your drum belt broken
if you have someone at home to dissassamble the dryer then
replace the belt and test the machine
this is a normal situation when the dryers are not tumble
May 26, 2009 | Whirlpool Dryers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryers Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
