Question about Binatone Lands Phones
Binatone cordless will not dial out, also no dialling tone, cannot recieve incoming calls.
This has only just happened.Batteries are new. Friends are calling me but phone is not ringing.
SOURCE:
vrabhilash
  • 52 Answers
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 37 Answers
SOURCE: no dial tone - phone rings for incomming call but I can't hear or talk
This can be a problem with your handset.
Have you tried a different phone in that same jack?
Posted on Apr 19, 2009
  • 84 Answers
SOURCE: Uniden 5.8ghz cordless W/2handsets has no dial
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Posted on Feb 26, 2010
My Binatone Idect Edge single DECT has no dial tone, just a buzz. The display is working, but I cannot ring out, or receive calls.
Plug a different telephone into the telco connector. If no dial tone, the Binatone set is defective.
Apr 03, 2018 | Binatone Lands Phones
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
I bought your digital cordless phones two weeks ago and now we recieve no incoming calls because they do not ring although we know that they are ringing also we cannot ring out we hear the number being...
They're not mine or FixYa's phones, they are yours.
Are you hearing dial tone before you ring out? When a phone doesn't dial or ring, it's the first sign that it's not connected to a working phone line. Try a regular phone in the same jack first.
Carl
Dec 13, 2009 | Philips Lands Phones
Cordless phone e3300 Binatone blocked
A friendly person sent me a manual for the e3300 and I managed to correct the problem.Thank-you for your concern and support.
Apr 19, 2009 | Lands Phones
Cannot get dial tone
try to make an incoming call to the phone in question by dialling the phone number from a mobile or whatever.if the phone does not ring then the line itself is not connected or has a wiring problem.
so if no dial tone and no incoming calls then check the line itself
Dec 20, 2008 | Lands Phones
Binatone phone won't make calls or ring - icarus 1500
binatone icarus 1500,no dial tone or incoming calls,cannot reset handset or base
Jul 28, 2008 | Lands Phones
Lands Phones Logo
35 people viewed this question
Top Binatone Lands Phones Experts
Marvin
Marvin
NOEL
NOEL
Harrie
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
