Question about LG LRE30755 Electric Kitchen Range
LG Range Element Will Not Heat
My LG LRE30755 range is literally 14 months old- 1 month past the warranty. @ 2 months ago we used the warranty to replace the circuit that makes the oven heat since it was off by about 100 degrees. Now 1 of the elements will not heat. It is the element with the option to heat a larger ring around it. The outer ring heats, the inner does not. Is the problem connected to the oven circuit or is this a new problem? I can't understand why it suddenly stopped when all 4 other elements work just fine. I am fairly pissed I have to pay for a repair on a range that is just barely out of warranty. I swear they make these things to break.
  • 2 more comments
  • joasis Apr 22, 2008
    i have the exact same problem with the same exact model in that the inner element is not working on the dual element burner. our problem cropped up 16 months after we bought it, so at least i got two more months out of it than the original poster did.
    my main gripe is that i have found it impossible so far to a) order the part directly from LG even though LG's "support" group has already diagnosed it, b) find a parts list or service manual, or c) find, verify, and order the part from somewhere else.
  • Anonymous May 01, 2008
    Want to buy & replace the Radiant Element myself, Were can I buy a Radiant Element?
  • Anonymous Dec 26, 2008
    I have the exact same problem.
  • nicknsarah Dec 29, 2008
    I have the exact same problem. Made the kids grilled cheese and it worked fine, one hour later went to make my husband a grilled cheese and it didn't work. The outer one works, but not the inner. $140 to fix the part! My MIL has a stove she has had for 25 years with no problems, me I get a stove and have it less than 2 years, and it breaks. The cheap **** they make now a days.
On my 30755 top left element will turn on but not adjust top right turns on to high only will not adjust . 3months out of warenty
Posted on Dec 14, 2008
    Sergeant:
    Champion:
  • 310 Answers
Un plug that element and test both the element and the socket
the soket for power and the element for olms
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
I have this issue and the oven not holding temp. What junk.
Element under 5 yr warantee.
$135 at http://www.repairclinic.com/SSPartDetail.aspx?s=b200a13c275g10i1345880&PartID=1345880
LG side by side fridge also freeze up in the humidty fan and ice tray warped so it spills water in freezer. Nice
Posted on Mar 15, 2010
LG has a limited warranty beyond the 1 year on parts and labor for the radiant elements and cook top. I believe its limited 5 years. basically you pay labor but not for parts. Those parts are quite expensive.......up to 450.00. So just paying labor shouldnt be too painful. Call LG before calling a repair man. Lg will give you a company authorized to do the repair.
Posted on Feb 23, 2008
No heat from my Electrolux oven fan is running but oven light not working the oven is only six months old
Thank you for your inquiry, friend!
Based off the information you have provided your Electrolux oven is not heating properly. I would recommend performing a reset on your range which you can do by disconnecting power from it for ten minutes. If that does not help to correct your issue it could be a faulty element or control panel. I understand your range is only six months old typically the warranty for a range is one year. I would contact the manufacturer for proper resolution regarding a warranty. I hope this is helpful. -Matt
Oct 17, 2014 | Electrolux Ovens
LG LRE30755 Electric kitchen range F-1 fault code
Hello- Control has failed. Replacement boards are available. Need complete model # to chk on part. Not too difficult to replace. Let me know if this info helps and if you need more- Thanks- ED
Mar 03, 2010 | LG LRE30755 Electric Kitchen Range
My 5 month over the range microwave will not heat,
contact the supplier who sold you the machine as it is still under warranty
Feb 17, 2010 | Kitchen Appliances - Others
Two of the touch pads for the burners are not working. 1. You touch the pad and two lines come up. When you touch high or low it does not change. 2. Touch the pad and the same two lines come up and the...
You have a bad membrane touch control. Check your owners manual for warranty on the electronic control. If it is out of warranty you need to call an authorized LG service dealer for a quality repair.
Jan 23, 2010 | LG LRE30755 Electric Kitchen Range
Oven Element
are you sure you have 240 volts now, if one leg is still out it wont heat,also check your electronic control panel if so equipped for an electronic fuse
Sep 29, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Scratches in my flat top Maytag electric range
report the problem as "thermal cracking" and it will be rplaced by whirlpool/maytag,
these things are hard to scratch, cleaning with a FLAT edge razor scraper is the norm, there are dozens of white cream type cleaners that work well with a scotchbrite and elbow grease.
Sep 04, 2009 | LG LRE30755 Electric Kitchen Range
LG range cooktop
Open the door and just under the front lip of the top there are a few screws that secure it to the body. Then you have to pull the maintop towards you. Its secured by two clips at the back.
Dec 01, 2008 | LG LRE30755 Electric Kitchen Range
My GE XL44 doesn't heat up to full temperature.
There are several things to check.
1) check the broil element
The broil element participates in the preheat and if the element isn't working it will take forever to reach temp.If the element is good 2)check the broil relay
If the relay does not activate when you press"broil" the control needs to be repaired.They are a few more things to check but you can start with the above.
We rebuild these controls.
Regards,
Howard http://www.appliancetimers.com
Apr 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Film between layer of glass on LG range
its not covered by warranty and it is cosmetic all ranges do this after a while its caused by the vents in the door for self cleaning i doubt the seals are defective as all ranges do this i get this quite a bit i can tell you how to disassemble it to clean but its more of a hassel than its worth for real because it will just do it again dont call a repair person because he will come over and charge you to tell you what i just did so what do you want to do reply ande let me know im here to help
Mar 28, 2008 | LG LRE30755 Electric Kitchen Range
LG LRE30755 Electric Kitchen Range Logo
1,830 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
