Question about Uniden Lands Phones
Uniden model exp7903. How to fix no dial tone and page/finder not working?
SOURCE:
jadyn08
  • 12 Answers
SOURCE: Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Posted on Nov 15, 2008
funkyjacob
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
SOURCE: When I get ready to dial, phone beeps 3 times
You must have an answering service from your phone company, and probably don't know about it. Try dialing your own # and wait for the prompts.
Posted on Aug 10, 2009
  • 3 Answers
SOURCE: uniden dect 1588 won't dial out. dial tone
press "menu", "global setup", "dial mode", choose "pulse".
I dont know why it works, but it does!
Posted on Aug 04, 2010
The problem is with my uniden phone model D1364 can't hear the tone when dialing phone
If you can't hear the dial tone, try substituting another phone to detect it. Also, if your Uniden phone is defective it can disable the dial tone when connected to the line.
Mar 08, 2014 | Uniden DECT 6.0 Cordless Phone ID
I have a line phone. I cleaned the top of it and must have touched something because I now have no dial tone. I recently purchased 2 Uniden no line phones no dial tone on them either. The model # is 1818...
Try reset the phone in question, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Jun 16, 2011 | Uniden Cordless Phone
What do you check when the phone lists a message of "Check TEL Line"? The phone cord in plugged in so I'm not sure where to go from here. I have a model DECT1480
Usually this means that the phone isn't detecting a dial tone. For diagnostic purposes, I like an old corded phone.
First try a new telephone cable between the jack and the phone. Then try the old phone and see if you have a dial tone. If you have a dial tone with the old phone but not the cordless, then the Uniden needs service. These phones are not designed to be fixed by the user. If the phone is under warranty, send it in. (see page 28 of the manual www.uniden.com/pdf/DECT1480-3om.pdf )
If neither phone gets a dial tone, check at another jack if you have several to see if the jack is the problem or if it is a more global problem. If the problem is at one jack, you may want to open the jack and check for a loose wire. Some wall plates hold the wires with screws; others use a keystone jack with the wires pressed into slots using a "punch down tool". Keystone jacks do not need the insulator removed from the individual wires. For the screw connectors, you do need strip the individual wires. The punch down tool is available at many hardware stores in the electrical section (for wiring homes for ethernet and other services).
If you do not have a dial tone at another jack, find where your telephone service comes into your home. Open the panel and identify how the connection is set up. Some use RJ-11 jacks. In that case, plug in your test phone and see if there is a dial tone at that point. If there is no dial tone, contact your phone company for service. There is a break in the wires coming into your home. The phone company will fix this for free. (If the service doesn't use an RJ-11 jack, you need a special adapter to test at this point. Your phone company technicians will have this.)
If there is a dial tone at the incoming service, you have a inside wiring problem. Check any visible phone wiring for damage to the insulation. If the problem is with wiring inside a wall past the jack, you will need a professional to track the break. Your phone company will fix this for a fee.
I hope this helps.
Dec 29, 2010 | Uniden Cordless Phone
I have uniden dxa1850 series phone. It was working fine, but now I can't get a dial tone. I tried the basic fix of unplugging and removing but it still does not work
Check that you have power (eg. Led indicator is on) to your Base station.
If you have power to the base station and you still do not have a dial tone, plug in a non-cordless handset to the phone socket and see if you have a dial tone on yor non-cordless handset, then you have a faulty base station.
Hope it helps and good luck! let me know how you go!
Dec 12, 2010 | Uniden Cordless Phone
Model UNIDEN UCIS-225 - Phone suddenly dials like a rotary phone. Does anyone know how to make it return to the non-rotary dialing?
two places<br /> 1. Manual switch on back of phone Tone or Pulse<br /> 2. Menu-Set Dial Mode - DTMF (tone) or Pulse
Aug 05, 2010 | Uniden Lands Phones
No dial tone and no ring on Uniden 5.8 GHz
I have the same handset and the 2nd one seemed to stop working after working great for 2 yrs. I placed both sets together and hit the PAGE button on the main handsets cradle. Both phone's were paged and, for some reason, the 2nd handset reset. It worked for me...or at least, something in what I did worked. BTW, H1 and H2 shows in upper right side (or at least it did after I paged)...and I made sure to put the phones in the correct cradle (H1 is the main handset). I just did this so hoping it continues to work!
Sep 29, 2009 | Uniden Cordless Phone
I want to change the dialing from pulse dialing to tone dialing
Usually this is a small slide switch on the phone or the base. It may even be on the side or bottom. It may be labeled P or T.
Jul 28, 2009 | Uniden DECT 6.0 Cordless Telephone...
Bought phone EX18560 Series yesterday. floolowed instructions to charge. Today I came home from work, plugged in telephone jack. phone will not turn on. Attempted to re-register (4X's). Led flashes....
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Aug 11, 2008 | Uniden Lands Phones
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Oct 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
24 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
