Question about LG Audio Players & Recorders
LG HT353SD standby LED is lit, but wont turn ON to function
The LED just blinking when the power button is pressed
    Top Expert:
  • LG Master
  • 52,423 Answers
Open internal fuse or power supply failure
Posted on May 19, 2019
SOURCE:
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
SOURCE: Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Posted on Aug 31, 2008
SOURCE: Computer wont turn on
I had the same problem here. And sure enough it was the USB socket that had been bent inside or broken off. Basically the pins were touching the sides of the casing and causing it to short on power up.
I used the method suggested above - get a screwdriver and (MAKING SURE THE POWER IS OFF) bend the pins from the USB socket back into shape so they are no longer touching the side casing. The USB port is unusable but the machine powered up straight away and is now working fine.
Thanks for your help!!
Posted on Oct 31, 2008
  • 197 Answers
SOURCE: will not power up fully
power supply call pioneer
Posted on Jun 07, 2009
localwonder
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Posted on Jun 21, 2009
Have a LG 55ls5700 tv that doesn't turn on but the red standby comes on and when i press the power button it starts to blink
Does the screen quickly blink on and then off? Does the standby light slowly blink twice and then go out?If these are the symptoms then it is probably a bad led backlight strip.This was the fault with my lg 47ln540v led lcd tv.I have written this up in a previous post more comprehensively.Hope this helps..
Mar 19, 2015 | LG 55LS5700 - 55 LED LCD Smart HDTV,...
My Sony Bravia HX8/46 will not turn on, I check all the power going to it and it all works. Is there something I can do?
Is the standby led on the front lit. If not likely the problem is with power supply. If the standby led is on does it go off when the power button is pressed? Does the led blink. If so count the blinks and get back. The power supply provides an standby voltage to the main board. If the standby led is lit then this voltage is present. When the power button is pressed the micro sends a turn on voltage to the power board. Normally the power supply will respond and all other voltages needed to operate the set will come up. if a component is shorted the micro will not turn on the power board and will usually give a failure code via the standby led.
May 31, 2013 | Televison & Video
Wont print error 5100
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off printer by pressing the power button
press the Resume button and press Power button.
Keep holding down Power button and release Resume button
Press Resume button 2 times then release BOTH buttons
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Nov 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
Remote code
You might consider the auto-search function.
  1. Turn on your TV.
I hope that helps.
Oct 05, 2009 | Innovage Jumbo Remote Control
Canon pixma mp-610
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 19, 2009 | Office Equipment & Supplies
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
Mar 04, 2009 | LG RU-44SZ51D 44" Rear Projection...
Sky remote
hi turn your tv on then if you get your remote point it at the tv then press tv on the remote then press the red button aswell as the select button together waite till the led on the remote blinks twice then press tv again on the remote then press the off button on the remote keep pressing tv then off pausing a second or 2 till the tv goe's into standby, once the tv goe's into standby press the select button till the led on the remote blinks twice then your remote should be programed into your tv. hope this helps.
Sep 20, 2008 | Audio Players & Recorders
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
26 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
Mike Duncan
Mike Duncan
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
