Question about Toshiba Satellite A45-S150 Notebook
Monitor Went "BLIND"!
The built-in monitor pannel/screen of my notebook went BLACK all of sudden after 2 years of regular use, and I can't see anything...!
Has anyone ever had the same problem? And any idea about how to fix it?
This is the 2nd notebook I'd experienced the same problem - last one was Sony laptop - and I suppose both Toshiba and Sony got their monitor pannel parts from the same manufacture (in China)!!
  • 4 Answers
Do you have a problem with the backlight on your laptop? If yes, you are not alone, that’s one of the most common laptop problems. In most cases the screen inverter is the culprit. Here are some LCD screen backlight failure symptoms that could be related to a bad inverter board:
- Laptop boots as usual but after some time the screen blacks out. You still can see an image on the screen but it’s very dim. You might even use a flashlight to see it better. Sometimes the backlight comes back for a while but then goes off again. In some cases you can turn the backlight on if you tap rapidly on the lid close switch.
- The screen always stay black and the backlight never comes on but you still can make out an image on the LCD. It’s dark, but the image is still there.
-In some cases you might hear a buzzing noise coming from the area where the inverter board is located, it’s on the bottom part of the display assembly.
NOTE: if you cannot see an image on the screen, most likely you have a different problem and there is nothing wrong with the screen inverter.
Posted on Feb 05, 2009
    Scholar:
  • 181 Answers
Actually, there's 3 major manufacturers of laptops and parts.
Can you connect to an external monitor and boot the unit up. You may have to toggle (F3 or F5 i think) between on board and external a few times. If you get an image on the external, it's probly the lcd inverter (#1), or the backlight (#2), or the cable is not completely connected to the lcd (#3)
Let me know how the external monitor test works and we'll narrow it down from there.
Good luck
Posted on Nov 28, 2007
Acer aspire 4736Z suddenly went black
Ram chips may be bad. Test it using an external monitor. If the problem does not occur on external monitor then you lcd screen may be going bad
Dec 24, 2013 | Acer Computers & Internet
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Hi , i was working on my computer and all of the sudden it went dead and its turns on but in the booting process the screen goes black
sounds like a failed backlight,
try plugging into an external monitor (you may need to use the function + change monitor key to switch to external monitor)
Aug 03, 2010 | Toshiba Satellite Pro L300 Notebook
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
Acer X233H monitor whilst in use suddenly went black
sounds like the video card went out or the cable shorted can you try that monitor on a friends computer?
Nov 30, 2009 | Office Equipment & Supplies
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Computers & Internet
My screen went black
If your Notebook's screen went blank you can do the following:--
1) Try booting with an external monitor. Connect the external monitor to the VGA port given to the Notebook.
Result:1 --- If the external monitor is working fine, then the problem is with LCD. If your Notebook is under warranty you can get it repaired free of cost.
If your Notebook is out of warranty you can go to HP.com and purchase the LCD screen (If you are in USA please go to this link :--- http://h20141.www2.hp.com/hpparts/)
Result 2:--- After connecting the external monitor even the display is not there, then it is the problem with the motherboard. If your Notebook is under warranty then you can avail free repair.
If your Notebook is out of warranty you can go to HP.com and purchase the Motherboard (If you are in USA please go to this link :--- http://h20141.www2.hp.com/hpparts/)
Feb 15, 2009 | HP Pavilion dv6000z Notebook
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
Toshiba Satellite A45-S150 Notebook Logo
144 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
