It is not responding
Remot control is runing ok but the main box is not responding to any comand.
I can turn it on only by pushing a smal emergency button on the main box.
Than it automatic heat & temp.
I em from Dubrovnik-Croatia and we dont have AKAI servis 100m radius
Thanks in adwans!!
  • 236 Answers
This is one of the best solution to do, look for unit who have same model as your unit( to your friends or neighbors) and test your remote control. If it wont work in another unit with same model then the remote control is defective, but if it works then its the receiver.
But try this solution first, if there is a reset button in your remote try to reset it then try the remote to your unit.
Note: sample only(reset button can be found either infront or at back of the remote control inside the battery compartment.)
Posted on Jan 15, 2008
What to do if PIONEER DVR-940HX is not responding at remote control comands
Have you tried a cheap universal remote just to verify the receiver is working for the infrared remote signal?
Jun 21, 2016 | Pioneer Televison & Video
What is the brand name and model number of your TV. It sounds like the main board of it is faulty. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 23, 2015 | Televison & Video
Need a universal remote code
Try 0000..
If that doesnt work I have another solution for. Westinghouse flat panel TV
TV 10812 probably has the correct IRsignalsfor enter programmed to the ok/select button. However the comcast and access remotes are intended to control a cable system so even in tv mode the remote sends the digit, ch+1and enter signals to the set top box.
There are two ways to defeat this.
1)Turn off channel lock. Sethe 9xx comand for this.
OR2) Assign a EFC for the Enter signal to the device mode.
1) Press TV
3) Enter 994 (two blinks)
4) Tap setup(DO NOT HOLD)
5) Enter 00069
6) Press ok/select.
The remote should blink twice and the ok/select button should work in the tv mode.
Use 1 unlessyou're going to use remote with cable box.
I hope this works...
Dec 17, 2014 | Westinghouse Televison & Video
I HAVE A PANASONIC PLASMA tx-P42X60B 18 months old. Nver been used to watch TV nut, my son has used it for playing X-BOX on and off. Lately the VIDIO display cuts off but th esound is on. Now IT IS NO
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 17, 2014 | Televison & Video
It does'nt turn on don't respond any comand The
I had a problem similar to this. I fixed it by toggling through the top buttons on the remote control. Sometimes the wrong button gets pressed and the remote cannotcontrol the unit it is supposed to. i.e. make sure TT320 remote has good batteries and then make sure if it has other buttons on it like TV, cable, DVD etc that the correct one is pressed to control the TT320. My TV remote would not control my TV and by chance my kids had pressed the satellite button so I had to press the cable button and then the controller startedto control the TV again.
Nov 02, 2010 | TruTech TT320
Tv would not respond to remote control comands .I just got a new remote control
You may need to program the remote with a code. The remote codes for the Norcent TV's are...
Once you program the remote to one of these codes it should work!
Nov 09, 2009 | Norcent Technologies LT-2022 20 in....
I have an LG 50pb2dr... The picture has fozen and the tv will not respond to comands from the remote or the tv controls. it does turn off after about 5 seconds when you hit the off button on the remote. It...
This is most likely a software fault within the Tv. I would advise contacting an LG dealer to arrange for the TV to have the software updated.
Jun 28, 2009 | Televison & Video
Slow to respond to comands
PLease a need control codes List for viwsat ultra box
May 06, 2009 | Bell Televison & Video
M275 tablet laptop LCD back light stop working.
it is look like your laptop does not have the light runing on your screen , open the screen and chek the smal part under de scrren is in the midle of screen with 3or2 smal cable on 1 side and 3or2 that difer from brand to brand smal the other side  wich is conected to the light sourece, that is the problem change that part and will be ok.
Jan 16, 2009 | Gateway M275 Tablet PC
No communication between remote controllers and main box
Push the X sign on the controller when its turned on then push the wi-fi button on the console its the small button in the front and push the wi-fi button on the controller too its the smallest button on top close to the rl trigger !!
Nov 07, 2008 | Microsoft Xbox 360 Console
Heating & Cooling Logo
506 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
