Question about Sharp EL-1750PIII Calculator
PRINT COLOR No matter what I do - the print only prints in red??? the plus sign however is in black - how do i fix?
Posted on Mar 26, 2008
  • 204 Answers appears that the ribbon is on upside down..The black has to be on the top and the red on the bottom. Just switch spools and turn the ribbon over..either that or there is a spring off the ribbon platform solenoid on the right side of the printer just below where the ribbon comes off the spool. If the spring is off or broken the ribbon platform will rise too high and print in red. Remotely the solenoid (little blue thing) could be bad or out of adjustment.
Hope this helps..this is usually all it can be.
Posted on Feb 06, 2008
I'm printing a double sided card. The back side comes out fine (white with black letters). The front side needs to be completey black with red letters. It keeps coming out blurry. How do I fix that?
It may be that the ribbon is mispositioned. There are quite a few points in the trouble shooting section of the owners manual. These start on page 53. Here is the link to the page at the zebra company site that you can download the manual from.
Hope this helps,
Best Regards,
Dec 29, 2010 | Zebra P120i Thermal Card Printer
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Why does my hp 1220c print letters double struck type red/black i
check you cartridge, is it new and genuine, if you have not troubles in cartridge, check the cleannig station
Mar 30, 2010 | HP DeskJet 1220c InkJet Printer
Black ink printing red
Some printers only use the black ink to provide a darker black. They also use the other colors to print black. That is they use all three to come up with black. If you color cartridge is out of two of the colors, you may be getting just the red. Otherwise you may have a hardware problem.
Jan 29, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
I just fix in new black and coloured cartridges and only black and red colours appear on my prints. the replaced coloured cartridge was giving similar print problems.
hi im josh in cebu phils. friend may i help you? it happen try to shake the cartridge that doesn't print.and install it again and just remember this: Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge. so thats all good luck
Mar 06, 2009 | HP DeskJet 1280 InkJet Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Sharp EL-1750PIII Calculator Logo
280 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
