My camer turns on but it wont let me take a pictuer when i cut it
As a little leave in the lense were i take a picture and I NEED HELP PLEASE ANY BODY THAT NOW ABOUT CAMERA JUST SEND ME A EMAIL MY EMAIL IS [email protected]
Re: my camer turns on but it wont let me take a pictuer...
Is this on a D70? It sounds like you have a point and shoot camera that is set in closeup mode. The little leave is normally the symbol for close ups (like of flowers).
there are several ways to download pictuere from pc to camers, u can copy past plus are r some softwares which automaticaly syncronize ur pic to ur device..
The Nikon D90 will take pictures with many older lenses, however there are some problems with using these lenses. Most of the time, they will not auto focus and many depending on type lens may not work in any mode other than "M" (manual). No P, A, S, AUTO or any of the "Scene" modes.
Set to "M" (manual)
You will have to set the exposure values (aperture & exposure time) and focus manually. Ken Rockwell has compiled a list of lenses that may help you learn more about using older lenses with your D90.
Please rate this reply if you found it helpful - good luck!
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Contact the makers customer support. The likely cost of repair however will be near the cost of simply replacing the camera. Get your friend to donate you the cost
Error 99 is a general fatal error. which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
