Question about Epson Stylus C60 InkJet Printer
Still got the lines on printed pages!
I cleaned the head with alcohol and it still prints these lines at random on my pages...Any other ideas?
  • Anonymous Mar 30, 2009
    your ***!
  • 91 Answers
On the printer their are options to allign the heads.try that and all the other service options ,takes awile and uses a bit of paper but its worth it.
Posted on Jan 20, 2008
Canon pixma iP1000 is skipping random lines when printing
Sounds like it's congealed ink on the print head. You can buy cleaning kits and do it your self. Relatively in expensive compared to leaving it into the shop.
Nov 16, 2017 | Office Equipment & Supplies
I have a Epson stylus the print has white lines on the letters as well as the photos. i have cleaned done head cleaning several times alignment no use it still prints the same
It seems that the print head is clogged.
You can choose to live with it by print at slowest speed (best photo or things like that) Or you may try to fix, however, it requires some skills.
A. USING ALCOHOL
1. Check if what print head was clogged: Print a test page. 2. Look at the test page, identify incomplete lines. what are there colors? For instant, blue line: clogged on blue head 3. Remove the ink tanks, and pump alcohol through the clogged print head 4. Do head cleaning to see if it works
If it does not work, try B method. Please only do this if you have experience on disassemble a printer, or you have nothing to lose, because incorrect handling parts from printers will kill it forever.
B. DIPPING THE PRINT HEAD IN BOILING WATER
1. Remove the ink tanks,. 2. Remove all the cables connect to cartridge 3. Remove the cartridge 4. Boil some pure water ( Aquafina of Pepsi is the best) until small bubbles appear 5. Dip the head of cartridge ONLY in boiling water for 2 minutes. 6. Put all things together.
Mar 26, 2011 | Office Equipment & Supplies
When printing photo's on my Cannon Pixma MP 500 there are lines horizontally across the photo at 4mm intervals. I have tried head cleaning and alignment to no avail. I have tried both Cannon original ink...
It's probably a blocked jet in the print head but could also be a page registration issue. Try gently wiping the print head with a cotton bud dipped in an alcohol based cleaner
Nov 28, 2009 | Canon Office Equipment & Supplies
Prints have lines throughout
Sounds like the printer head is dirty and needs to be cleaned. If after removing the ink cartridge and cleaning the print head with DENATURED ALCOHOL NOT RUBBING ALCOHOL, does not produce clean prints with out the lines, you might need to replace the actual print head mechanism. The print heads do not last forever and need to be replace every so often.
Cheers,
Keith
Sep 19, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Printing coloured lines on paper across the page
Try to clean the area around the head output (sprayer). I think it's caused by the waste ink around the head.
May 29, 2009 | HP Office Equipment & Supplies
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Oct 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
Epson Stylus C60 InkJet Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
