Question about Avaya Lands Phones
Avaya general voicemail not picking up
Our mail line rings and rings and no voicemail is picking up. All mailboxes say active. Avaya IP phones are desktop 1410
SOURCE:
SOURCE: Avaya 5610 IP Phone
Press mute reset (mute 73738)
Posted on Oct 21, 2008
  • 10 Answers
SOURCE: Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Posted on Apr 02, 2009
  • 10 Answers
SOURCE: How to configure Avaya's IP Phone 5610?
Ensure the reachability of the call server from that port. To ensure the same, configure a laptop with the IP address and default gateway of the intended IP phone. Then try pinging the call server from the laptop.
If this works then the setting should work for IP phone too. Double check on the router IP address and Vlan ID configured on the phone.
Vit Avaya BP
  • 211 Answers
SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: Avaya 6416D+M, rings half ring, then goes straight to voice mail
you might status the phone to make sure that send all calls somehow is not on. :)
Posted on Nov 05, 2009
Voicemail rings busy and will not pick up incominig calls
Is this the Automated Attendant (AA) not picking up? If so, check your voicemail extensions (#505, Group 7). If this is for an extension, make sure a mailbox has been setup.
Jul 04, 2014 | Avaya Partner 34B Corded Phone
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
Apr 21, 2014 | Avaya Definity PBX Phone 6424D+ Gray
I have the Avaya partner voice messaging and the mailboxes have been set up but when the phone rings twice it goes to fax not voice messaging. How can I fix this
Your voice mail extensions are programmed incorrectly in the system. You need to enter the System Programming mode from Ext 10 or 11 and use #607 to set the correct voicemail extensions.
Aug 28, 2013 | Avaya Corded Phone avaparp18d
I have no messages, however the red light will not go off
Are you the reception phone? Is it possible that the general mailbox is lighting it?
Which voicemail and system do you have?
Jul 29, 2010 | Avaya 5610 IP Phone
Can't change voicemail on my 5410 Avaya digital phone
The auto attendant greeting, or the general mailbox greeting?
May 15, 2010 | Avaya 5400 Series 5410 Phone
Someone left employ and we have no idea what voice mail password was for avaya 18d phone on merlin partner 6.0
Which voicemail system do you have? You will need to have the admin reset that mailboxes password, which requires that you get into the admin part of the voicemail system.
May 07, 2010 | Avaya Corded Phone avaparp18d
The avaya phone system rings like once 1/2 and goes to voicemail
You can check your ringing setting and you can reset that also for more ring before go to voice mail box.
Mar 29, 2010 | Linksys SPA941 IP Phone
How do I change the voicemail on our avaya partner phone system?
What do you mean, "change"? The AA greeting, the General mailbox, the password, the voicemail module itself?
Feb 16, 2010 | Avaya Lands Phones
USED AVAYA ACS V7 PARTNER MAIL vm SYS ANSWERING ALL CALLS, I CAN'T ACCESS VM SYSTEM
Depending on the type of voicemail you have, That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming2.gif.
Oct 06, 2009 | Comdial Avaya Partner ACS Phone
AVAYA PARTNER ACS PHONE SYSTEM - Voicemail/Greeting capability
Yes you can have the 2 lines answered by a particular mailbox instead of the AA greeting.
Would need to know the model of the voicemail system that is installed to see if there are more than 1 AA menus.
Oct 06, 2009 | Avaya Lands Phones
Lands Phones Logo
21 people viewed this question
Top Avaya Lands Phones Experts
Cabanaboyz
Cabanaboyz
Norman Worley
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
