Question about Samsung SpinPoint P120 SP2514N 250 GB IDE Hard Drive
Samsung SP2514N discs....
I am in dire need of restoring the memory on my external hard drive. The problem started with no sound from the drive and pc not recognizing it anymore. after some investigating i found the motor was locked up and discs not spinning (would not budge even by hand). So i had the bright idea to see if i could just replace the motor. No such luck and stopped trying after about 2 weeks and broke down and purchased a new drive and planned to simply swap the discs. At least i thought it was cut and dry. got it all back together and the motor spun and drive make some clacking noises but didnt recognize the drive still (dev mngr showed an issue). the ext drive case (Zynet) was blinking which never happened before. I opened her up and found the the reader tabs were slightly bent when i replaced the discs. Yet again, i purchased another drive and it works fine but i am hesitant to remove the discs again to replace them. any ideas as to how i can get the discs to work without damaging anything? I need the information from the 1st drive as it contains my client information. Help please....
-Paul
  • Samsung Master
  • 787 Answers
Seriously? When data recovery companies open up a hard drive, they do it in a clean room to protect the disks. The heads on the arms float so close to the disk surface that a speck of dust can get stuck and scratch the surface. If you bent the "reader tabs", that means you have already experienced multiple head crashes.
Also, the base of the arm is a powerful magnet, if the disk comes in contact with this, it will wipe the data.
Even if you do everything perfectly, just putting the disks into another drive will not work unless you get the same drive and sometimes, the firmware version even matters. Unless the drive is compatible, it will try to read data in the wrong locations.
Posted on Mar 05, 2017
Teckies
  • 226 Answers
SOURCE: Samsung SP8022N / Hanaro 2
ok.
ok you said that you have hanaro 2 and you want to sasve something to that drive.
this is what you got to do set your hard drive as slave. ok
Posted on Jan 26, 2008
  • 508 Answers
SOURCE: Portable HDD stopped working and not recognized
Sounds like hardrive maybe bad try on another computer! Good luck!!!
Posted on Jun 22, 2009
  • 54 Answers
SOURCE: My Passport Drive is no longer recognized by windows
Check to see if the drive is available in disk management, if so and it's got a blue bar at the bottom, try changing the drive letter. If not, try the following:
Normally with the passport drives, you receive a shorter USB cable (this is because the drive relies on power from the PC, which your normal length USB cannot offer sufficiently. If you are using a short cable, try connecting the drive to the back of your desktop PC, this generates more power than the ports on the front (the ports on the front are actually hubs). If none of these options work try it on another PC, using the steps above.
If you still have an issue, the drive has most likely failed and you will need to get data recovery done to retrieve your data. If you do so, contact samsung for warranty information, so that your warranty doesn't become void.
Posted on Jan 26, 2010
  • 158 Answers
SOURCE: my external hard drive fell
Yes the two hard drive cylinders crashed together making the drive dead.
Posted on Nov 04, 2010
adracamas
  • 344 Answers
SOURCE: We have been using a
Assuming you don't hear any activity it might be the power supply that has died. Check if it's under any warrant.. if not you can always rescue the hard drive by taking it out of the enclosure and plugging it into your PC. Odds are it's a SATA drive. Either way.. taking it out of the enclosure will rule out of it's the hard drive or the components. Good luck.
Posted on Mar 19, 2011
I have a Samsung SP2514N (250GB/7200rpm/8M/PATA) drive that I am trying to use as a USB drive on my laptop with Vista on it. The device manager shows that there is a drive there, but that is all. It does...
If your using an external drive case, the jumper pins should be set at "single". If that doesn't work you can try moving the jumper till the drive shows up, or use no jumper at all. If it still doesn't work after trying all jumper positions or no jumper then the drive could be bad. Make sure to power off the drive before changing the jumper.
Feb 15, 2011 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Hi I have an sp2514n hard drive. It was in a external hard drive case and was accessible via usb2. However the power to the case ceased so I removed the hard drive and installed it in a PC. The PC...
What you can do is go to Start-Run, type in CMD and hit Enter. Then, if you have only one hard drive partition and one DVD, type this
chkdsk /f e:
chkdsk is a command-line disk checking utility, the /f string stands as "scan and fix" instruction. The last letter (e:) is the Samsung's drive letter.
I had a similar problem with 1.5TB hard drive and the CHKDSK procedure fixed some partition parameters.
If this doesnt help, use the Easeus free partition recovery tool. It helped me on numerous ocasions. Install it and run the Partition Recovery procedure and just follow through the steps, they're pretty self-explanatory.
Jan 13, 2011 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Dead Samsung sp2514n hard disk. I read something about problems with PCB caused by overheating. Any possibility to recover the information of this hard disk?
Hi
Thank you for your query
Unfortunatley if it is dead i.e. there is no power going to it then you will not be able to recover the data as there is no way of reading it
I hope this helps
Mar 08, 2010 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
I need a sp2514n hard drive
http://www.amazon.com/Samsung-SpinPoint-P120-SP2004C-internal/dp/B000BONHS2/ref=sr_1_fkmr0_1?ie=UTF8&qid=1265381348&sr=8-1-fkmr0
this link will solve your problem..
plz give vote and ratings..
Feb 05, 2010 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Is my hard drive broken? Cant get it recognised on other PCs
I'm having a similar problem with the same Akasa integral enclosure, so far I have tried 3 different hard disks and not one of them will work properly and on two different computers.. , all of the hard disks I've tried are Samsung .. but I'm sure that makes no difference. I plan to send back the enclosure to where I bought it from and get a different one from a different manufacturer.
Dec 10, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Hi, My hard drive recently crashed. Can you suggest a replacement? I have SP1203N now.
Hi
My hard drive also crashed and I installed a Samsung SP2514N 250 GB and I found it very good.
Give it a try.
Nov 11, 2009 | Samsung (SP1203N) 120 GB Hard Drive
Samsung SpinPoint P120 SP2514N 250 GB IDE Hard Drive Logo
150 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
