Black & Decker AM8 Coffee Maker
Problem for Black & Decker AM8 Coffee Maker
I have a Black and
By strainham on Aug 07, 2009
I have a Black and decker DCM100b. It was brewing slowly. I tried rumning the vinegar and water solution and now no water is comming through at all. We have owned it for about 6 months
Comments:
Aug 07, 2009
- the plate is hot. Just no water is comming through.
Aug 07, 2009
- The previous expert said the heating elent gone. It is working. still no water comming through
Aug 07, 2009
- I can hear it staring to woek then nothing. It is hot and steam comes up through the hose but no water
Aug 07, 2009
- actually what I did was loosen the hose and primed the pump with water and the water began to come out. So far so good. Thanks for the help though. I guess a inexperienced woman can fix something afterall.
Solution #1
posted on Aug 07, 2009
Somewhat Helpful)
MNfisherman
Rank: Wiz
Rating: 85%, 2676 votes
Can you hear the pump running? If so, then you may have a clogged or kinked hose. Have you tried to let it cool completely before trying to use it? If there is stuff in the hose and didn't get flushed out, then when it is stored, then stuff hardens up in pump and in hose.
Comments:
Aug 07, 2009
- It may be bad pump, or just not hot enough to clean tubes and push out liquid.
Aug 07, 2009
- PERFECT! That was my next suggestion. Good Job!
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
baboono
Rank: Wiz
Rating: 82%, 759 votes
It sounds like the heating element is gone bad feel the base to check and see if it is hot but be careful no to burn your hand just touch it quickly if it is not very hot the element is gone bad. the heating plate on the bottom acts as the water pump/heater for the unit as well so if it is not hot enough it will not boil the water to cause the water to flow through the machine.
Was this helpful?
Yes
No
Popular Solutions for Black & Decker AM8 Coffee
Questions and Unsolved Problems for Black & Decker AM8 Coffee
Do you recommend Black & Decker AM8 Coffee Maker?
Answer
Answer
how do you change the rubber seals on a 3 head commercial wega espresso machine. Do they just pop... (More)
Answer
Keurig B80 coffee maker pump stops working shortly after brew button is pushed
Answer
I have a black and decker space maker and the flow stopper on the brew basket the stops the coffee... (More)
Answer
I have an AM8 Black and Decker coffee maker. The inside part that delivers the water to the pod is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker AM8 Coffee...:
Top Coffee and Esp... Experts
Rank: Wiz Wiz
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
