Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer canon pixma ip 3000 will not turn on - Canon PIXMA iP3000 InkJet Photo Printer
SOURCE:
SOURCE: cannon pixma ip 3000 ink jet printer
Go here: http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Select the drop downs for Printer, Pixma iP Series, ip3000
On the next page, select the Drivers & Downlaods tab. Use the drop down box to select your OS (operating system).
In the Drivers box, click on the red link. On the new page, if the file name ends in "exe", there should be a checkbox near the bottom to select Automatic Installation Option. Check that and hit the I Agree button.
Hope that works for you.
Posted on Nov 10, 2007
  • 5 Answers
SOURCE: Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Posted on Jan 24, 2008
jaznet
  • 75 Answers
SOURCE: canon pixma ip3100 driver
Try this link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10238
this driver is applicable for model ip3100
PS, rate this solution...tnx
Posted on Sep 14, 2008
rionxz
  • 48 Answers
SOURCE: Installer cannon pixma ip 3000
You can download the said installer through this links:
http://software.canon-europe.com/products/0010094.asp
Posted on Sep 28, 2008
SOURCE: Printer does not power up
My Canon IP3000 would not turn. It turned out to be the Print Head. It had burnt out and gone short circuit. This caused the built in power supply to shut down, hence, the printer appears dead.
Now, how do you get the Print Head out when it is locked down on the left side (your right side if facing the printer)? Open the top lid and inside you will see a chrome sharft, about 10mm in diameter, that the Print Head slides along. Put you finger under this bar and lift it 3 to 4mm. It's under spring tension. The Print Head will also rise, releasing it from the lock. With your other hand, slide the Print Head to your left. You can now release the bar and move the Print head freely.
To confirm the fault, try to power up the printer with the Print Head removed. Don't forget to put the lock bar down first, to stop it hitting the cover when it tries to go home.
Posted on Nov 28, 2008
Ip 3000 yelow light
my plm is ink absorber is Full software free download canon pixma ip 1300
Aug 24, 2013 | Canon PIXMA iP1300 Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
Your Problem: canon ip service error 6a00
Had this error and did the following to solve the problem.
Turn the printer off.
Open the top cover and move the printer cartridge to the left.
On the right you can see a white part.
Press it down.
Turn the printer on.
if that doesnt help then there its better to call canon...
thank you have a nice day
Jun 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
No print
Hi there you can try this.
Canon IP 2000 / 3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon pixma ip 3000 power problem
The cord is a tough one. but it has to be pushed in very hard in some models. are you sure it is plugged in at the back of the printer hard? push extra hard.
Feb 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Lost my set up disc for my Canon ip 3000 printer
Sir,
Click this link to get ur software / driver
Thanks
good luck
Nov 26, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
Clive
Clive
old marine
old marine
Ekse
