Question about The Office Equipment & Supplies
HP7510 will not print black. I have removed the cartridge and cleaned as suggested but no success. Could my printer be finished?
SOURCE:
SOURCE: new black print cartridge not working
I only use refill HP inks. When the cartridge prints gray instead of sharp black it means the ink well is clogged. Yes, that can happen on a new cartridge. Sometimes it happens when they put too much ink in the cartridge, or even heat can make it not work. Also streaking black lines is the problem of the ink not coming out properly. Easiest thing to do is go to a refill station like Cartridge World and have them test it or clean it out. You can also make sure the printer, not the cartridge is clean. Ink builds up an pools. Get some Q-Tips and clean up all that spilled ink. Sometimes in the software it says you can clean the print head, do that too.
Posted on Jun 17, 2008
myjosh007
  • 530 Answers
SOURCE: My Canon iP4500 does not print with "black" cartridge
hi im josh in cebu phils. may i help you? Friend the problem is your cartridge and on the tank lever.it causes spoiled ink that stuck on it. To solve this problem. you may visit the Cannon Pixma support manual site and follow the steps there:here:
http://www.generalmanual.com/Printers/Canon-PIXMA-iP4500-Photo-Printer.htm
good luck friend hope i helped you.
Posted on Mar 14, 2009
  • 26 Answers
SOURCE: MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Posted on Aug 18, 2009
CW Oly
  • 240 Answers
SOURCE: Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Posted on Dec 19, 2009
supertech6
  • 513 Answers
SOURCE: Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Posted on Mar 20, 2010
Epson WF-7620 will not print black.
I had a similar problem on my 3640 and had to run the clean cycle about 20 or so times. If you feel you are capable, you can also remove the print head and do a manual clean. YouTube has a few videos on how to do it. I have done this to one of my printers with very good success.
Apr 26, 2016 | Epson WorkForce WF-7620 Wireless Color...
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
DeskJet 895Cxi Printer ran out of black ink before my summerholliday. Back on job monday I replaced a new inkbox, HP 45 Black. The colour ink was changed just before my holliday. Still the orange light...
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
http://www.fixya.com/support/t5472914-hp_deskjet_932c_went
Aug 04, 2010 | Office Equipment & Supplies
Black ink not printing
I suggest you replace the blank ink cartridge because it is possible the ink inside is finished.
Better still, if you can remove the black ink cartridge and check if the ink is still ok to print and you can equally try the black ink on a similar printer to see if it will print.
If it did not,then replace with a better one.
I wish you best of luck.
Apr 05, 2010 | Epson Stylus C62 InkJet Printer
Mar 14, 2009 | Canon Pixma iP4500 InkJet Printer
Very feint print
Do you have a the CD ROM for installing the printer ? You can clean the printer using the instructions suggested. It will ask you to print a test page after cleaning and alignment. The CD ROM gives you all the information.
Sep 19, 2008 | HP DeskJet 670c InkJet Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
New black print cartridge not working
Sep 14, 2007 | HP Photosmart 2610 All-In-One InkJet...
14 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
