Hi I have a flsun QQ 3d printer I just change stepper board and I can't find a defined configuration H file just for this printer a lot of file for delta type prints but none seem to work this printer
Hex file dedicate to my printer
SOURCE:
jaylex
  • 417 Answers
SOURCE: HP LaserJet 2420 Printing trouble
I think that Odyssey user is right it maybe that the print driver is not compatible with the program you are using goto hp.com or hp.co.uk and download the PCL 5e driver
Hope this helps you
Thanks J
Posted on Jan 13, 2008
  • 300 Answers
SOURCE: tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
Posted on May 18, 2008
SOURCE: TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Posted on Mar 26, 2009
  • 65 Answers
SOURCE: PDT 6846 Hex Image Modify Query
I have sofware to rebuild your hex files I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Posted on Jan 22, 2010
antosarmy
  • 39 Answers
SOURCE: PRINTING WINGDINGS WHEN I PRINT PDF FILES
Adobe PDF reader tends to print webdings/wingdings in its version 8 incarnation. Download FOXIT reader free from filehippo.com and try to print your document from that instead of Adobe. This nearly always fixes the problem. antosarmy
Posted on Feb 27, 2010
Where should i get best colour 3D printers?
Hi! Now a days 3D printer is the best type of printer. It is used in every company for best printing work. You can get 3D printer available everywhere. You can search on the internet also for best online stores and visit that sites. Last time I use 3dprinting service online from www.iannone3d.com, Which is a New Jersey based Rapid Prototyping and 3D Printing Service Bureau. Thanks a lot.
Apr 21, 2016 | Office Equipment & Supplies
Where should i get best 3D printer colour ink?
Hi! Now a days 3D printer is the best type of printer. You can get 3D printer available everywhere. You can search on the internet also for best online stores and visit that sites. Last time I use 3dprinting service online from www.iannone3d.com, Which is a New Jersey based Rapid Prototyping and 3D Printing Service Bureau. Thanks a lot.
Clogged Extruder head
It is not unusual for the extruder to get clogged, especially when changing filament. the problem occurs when pulling the hot filament out and a tail forms within the filament channel. you can remove the stepper motor and try and pull the filament out. also unscrew the extruder tip and see if it will pull the clog out with it.
I use boiling water to clear the extruder head and it works nicely. if it is stuck in the filament tube you may need to pull the filament tube also to clear it out. it is also possible to remove the stepper motor and heat the extruder on preheat and push the tail inside the tube.
once this is done you should be able to "Load Filament" normally and once the new color id extruding your good to go.
May 13, 2013 | MakerBot Replicator 2 Desktop 3D Printer
Hi, I wonder how to use a TI89 to graph a multivariable functions's 3D picture. Thanks.
First you must configure your calculator to perform 3D graphics
Press MODE
1.The first line shown is Graph. Unfold the hidden menu list with the right arrow and choose Graph 5:3D
2. Press ENTER to validate.
Now you must define the surface you want to draw
1. Press the [diamond] key then [Y=] to get a list of function names, the first of which is z1
2. Enter the following function (or your own) z1=(x^3*y-y^3*x)/390
( x cubed times y -y cubed times x) divided by 390.
3 Press ENTER.
Graph the function
Press the [diamond] key then [GRAPH]
The graphing screen displays progress in %. When it is finished you will see a weird sombrero.
Hope it helps
Mar 21, 2011 | Texas Instruments TI-89 Calculator
Unable to print Zebra labels on a Zebra 105 SL printer. Sending the label from an I-Series computer through the EntendNet 100x print server to the Zebra printer. Does ExtendNet 100x support Zebra ZPL2...
A print server should just be a 'through-put' device, and the codes should go fine. ZPL-ZPL2 codes are subequently sent as comms to the printer port. Are you using seria; or parallel input to printer?
Yo can capture the codes to a file, and review if they are correct. The file would have to be viewed in a hex editor.(write to a file through the driver)
I routinely use different mfg. of print servers for thispurpose if the printer does not have an internal ethernet port. The only problem I have run into is a problem in network where a slow download is enountered.
Feb 11, 2011 | Troy ExtendNet 100x Print Server
With the tec b472 qq ..i get mesage RC000;W-13807 DO U KNOW WHAT THAT COULD MEAN ..THANKS
this means that you have a field missing in your label definition.
Ypu must have a PC000;XXXX,XXXX,etc field defined first
Feb 04, 2011 | Toshiba TEC B-472 Thermal Label Printer
Xerox 3635mfp: On defining network scanning one needs to define the default file repository. This causes no problem but on pressing "Apply" (Via explorer interface to IP of printer) the system...
Xerox are aware of this problem and are working on a solution. I think the workaround is using capital letters for the administrator. Xerox software support should be able to help with this.
Jan 17, 2011 | Xerox Phaser 3635MFP/X Multifunction...
Canon mx300 wont receive fax , it is a dedicated
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Canon-PIXMA-MX310-Manaul.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Feb 01, 2010 | Canon MX300 Office All-In-One Printer
k24674
Marvin
Marvin
