My remote stopped working. i have replaced the batteries twice. serial #05B14
  • Televison & ... Master
  • 390 Answers
Hello Cstan88086, verify that the contacts of the batteries in the remote control, are clean, without any type of insulating dirt
You can test if your remote control emits, with the help of a camera, turn on the camera and point the emitting LED of the control to the camera, press any button and through the camera, you should see that the emitting LED turns on, if it does not happen you have a problem with the remote control
If you have technical knowledge, you can replace the issuing Led
I hope you can solve the problem
Greetings Franco Dosil
Hola Cstan88086, verifica que los contactos de las pilas en el control remoto, se encuentren limpias, sin ning?n tipo de suciedad aislante
Puedes probar si tu control remoto emite, con la ayuda de una c?mara, prendes la c?mara y apuntas el Led emisor del control a la c?mara, apretas cualquier bot?n y a trav?s de la c?mara, deber?as ver que el Led emisor se enciende, si no sucede tienes un problema en el control remoto
Si tienes conocimientos t?cnicos, puedes reemplazar el Led emisor
Espero puedas solucionar el problema
Saludos Franco Dosil
Posted on May 16, 2019
3 Suggested Answers
SOURCE:
SOURCE: Amana Portable A/C Model#AP077R Remote control
I have a similar problem. The remote works for 5 to 10 minutes then no longer works. If I take the batteries out of the remote for 10 minutes (or longer) and reinstall them, the remote will again work for 5 to 10 minutes. I got a replacement remote from Frys and it behaved the same way.
Posted on Jul 09, 2008
  • 362 Answers
SOURCE: I have a 42 inch
Hi rampersad82, We need to check the functionality of the remote. Press and hold the up volume button, watch the light (led) on the remote. If the remote is workingyou will see a slight pulsing of the light. If it is not working the light will stay bright with no pulse. Let me know what you find I can assist further. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 11, 2009
My remote has stopped working. We have replaced the batteries with no luck because of this we cannot switch between sources My TV is a Philips 42" Model # 42PFL3603D/F7 Serial # VA180905005250
Hi:
The IR remote sensor in side of the television need replacing, this is the sensor that receives the commands from the remote and relays them to the microprocessor of the TV. Have the remote sensor replaced.
Mar 10, 2011 | Philips Televison & Video
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
Toshiba remote stopped working
remotes run on infra red technology. that part of the remote could be damaged. if this is the case its just cheaper to get another remote. just remember if you get a universal one .. you keep the code book.
Apr 28, 2009 | Televison & Video
The Remote control just up and quit working.
Sounds like the circuit board inside the casing has a solder break. this solder connection was probably connected to the battery post inside the remote. it only takes a solid drop on a hard surface to cause this breakage or, it could be poor manufacturing as well.
Jan 27, 2009 | Audio Players & Recorders
Amana Portable A/C Model#AP077R Remote control worked twice and then stopped working. Replaced batteries twice but no luck. Any suggestions?
Jul 06, 2008 | Heating & Cooling
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
I can't get the remote to work with my disc changer
take down the remote and check the circuit for lose solder if there there is any resolder all whole circuit.if that does not work take a look on the amp IR could be it has cold solder or the IR needs to be replace,for parts replacement contact www.dalbani.com
Apr 06, 2007 | Sony RM-U185 Remote Control
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
