Question about JVC Audio Players & Recorders
I have a JVC UX D88 micro system and the CD operation does not work
When I insert a music CD and close the door, the CD spins but does not play. When I pass the play button the CD door opens. I do not have a remote. Can you pease suggest a fix?
  • JVC Master
  • 584 Answers
Hi Mark, so you account for your JVC, you are not reading the CD, should you indicate on the display, "NO DISC", have you tried to clean the lens of the laser reader, with a cotton swab with a little alcohol?
Another possibility would be that you had, low emission of the reader, which could be adjusted, using the necessary instruments
If after cleaning the reader, it does not work, I suggest you look for a specialized technical service
I hope to solve the problem
Greetings Franco Dosil
Hola Mark, por lo que cuentas tu JVC, no esta leyendo el CD, deber?a indicarte en el display, "NO DISC", has probado limpiar la lente del lector l?ser, con un hisopo de algod?n con un poquito de alcohol?
Otra posibilidad seria que tuvieras, baja emisi?n del lector, el cual se podr?a ajustar, utilizando el instrumental necesario
Si despu?s de limpiar el lector, no funciono, te sugiero que busques un servicio t?cnico especializado
Espero logres resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/jvc_fs-d88.pdf/download.html
https://www.manualslib.com/products/Jvc-Ux-D88-4185098.html
Posted on May 15, 2019
SOURCE:
headman333
  • 82 Answers
SOURCE: JVC micro system hi fi model UX-DAB11
One possible problem is the display IC of your JVC is damaged already or it is not connected properly due to mishandling. display IC has small pins and therefore have small connectors, even if you trace those connections you may find it hard to solder it, but if you have the right tools you may proceed. To trace the pins of the display IC if it is connected you must use an Ohmmeter. Here is a simple steps: an ohmmeter has two wires that has a pin on both ends, most tester has colored wires the red and black. You must point in contact either pins on the subject points in the circuit and the other pin on the circuits also it must be in contact. If the ohmmeters display gives a reading of 0, then there is connection, otherwise it will give a number that indicates there is resistance which means there is no connection or poor connection on the subject. Repeat this procedure until you find all possible disconnection. NOTE: Do this only on the part on the dispaly IC and the DISPLAY connections.
But the best thing to do about it is to bring it to the service center.
I hope i've provided some form of help to you.
Posted on Feb 15, 2008
SOURCE: Opening the CD player on a JVC UX-RC7 micro component system
Hello i had the same problem..maybe you have already fixed this but on the back you have the speakers and a pair of red and black switches, you have to put the wires into the holes on the TOP (not the sides) of the little box on the back...then once you have put the wires in flick the flaps UP :)
Sorry if you have already solved this problem but I hope it will come in use for someone.
Thanks
StepheeJay..x
Posted on Apr 22, 2009
  • 296 Answers
SOURCE: Looking for a User Manual JVC UX-1 Micro System!
you can find out the manual from
http://safemanuals.com/user-guide-instructions-owner-manual/JVC/UX-V10%20@@%20UX-20R-_E
Thanks!
mannu_rakesh
Posted on Aug 06, 2009
  • 100 Answers
SOURCE: I have a jvc micro
check cd
Posted on Sep 23, 2011
emissionwiz
  • 84966 Answers
SOURCE: I have a JVC UX-P5R micro compartment system. The tape works, the radio works but the cd player will open and close the drawer and will not play disk. Any ideas?
The player is defective, it makes no diff why, because you can't buy parts for this.
Posted on Feb 22, 2017
Testimonial: "Many thanks. I thought this might be the case. One can only hope someone may have a simple answer."
How can i open my cd drive to insert my cd?
If the button on the drive won't pop open the drive, then you need to find out what is causing it to stick closed. Most drives have a tiny hole on the door so you can push a paper clip in it to open the door.
Jun 17, 2015 | Computers & Internet
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    My disc is not playing nor can I eject it is there some way I can do this I have a Lenovo Think Centre M90z
    The drive can be easily removed once removed you can then use the paper clip from the back and push the tray open
    Jan 05, 2015 | Lenovo ThinkCentre Computers & Internet
    My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
    THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
    May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
    My Marantz CD 53 CDplayer door is not opening. what is the solution
    You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
    Mar 31, 2014 | Marantz Audio Players & Recorders
    My laptop win8 has a CD jammed into it by inserting it not secure in the tray. The door would not open. I then inserted a paperclip into the pin hole which released the door. The CD was not there and I...
    you can remove the disc drive they are made to be replaced once you slide it out is only a matter of 4 - 6 little screws ant the cover pops off remove the disc and reverse the procedure piece of cake. :)
    Sep 30, 2013 | Computers & Internet
    How do I unlock the CD tray on my JVC UX-GN6.
    HEY I HAVE JVC- MODEL CA-UXGN6. CAN U PLEASE HELP ME UNLOCK MY CD TRAY. I DO NOT HAVE THE REMOTE....
    Apr 13, 2011 | JVC UX-GN6 120 Watts Micro Component...
    24 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    stynger007
    Level 1 Expert
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
