Powers on but buttons on tv and remote dont respond or are very slow to. Screen has bars of light obscuring it.
  • Televison & ... Master
  • 390 Answers
Hello Patricia, comment on the brand and model of television, which you mention with those problems, so try to find a possible solution
I wait your answer
Greetings Franco Dosil
Hola Patricia, comenta la marca y el modelo de la televisi?n, de la que mencionas con esos problemas, para as? tratar de encontrar una posible soluci?n
Espero tu respuesta
Saludos Franco Dosil
Posted on May 16, 2019
SOURCE:
konzzz
  • 255 Answers
SOURCE: plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
Posted on May 28, 2009
  • 13 Answers
SOURCE: Vizio VW32LF powers up no sound no picture unplug to turn off
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
  • 1645 Answers
SOURCE: Sanyo TV DP42647 No picture or sound, remote does nothing
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
tgvern
  • 281 Answers
SOURCE: console does not respond to all remote actions, ie
I would try to re-sync the controller to the console.
1. Power on Wii
2. remove battery cover from wii remote; press sync button on remote, will cause LED's on remote to blink.
3. Press the sync button on the console (it is located in the memory card holder on the front of the console)
4. The remote is connected once the LED stops blinking. The lit LED indicated what player # the connected controller refers to.
If you are still having trouble then delete the configuration info first and then re-sync the controller to the Wii.
Do this by holding the SYNC button on the console for 15 seconds after turning the unit on (once you see the health and safety screen). After you do this you will need to re-sync the controller individually.
It also warns of bright light sources like sunlight near the sensor bar, highly reflective surfaces (mirros, etc.) behind the sensor bar, sources of infrared radiation (portable heaters or fireplaces) or radio interference from cordless phones, cell phones, etc. as possible causes of interference. See pages 22, 32, 34 of your Wii owner's manual for full information, or call 1-800-255-3700 if you are still having difficulty.
Posted on Dec 31, 2010
SOURCE: Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
Posted on Mar 21, 2011
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
Remote control slow to respond to Bush tv (LT42M1CFA)
Even though your TV s remote control emits infrared light, it might have not sufficiant frequency as it supposed to be. The fault with its resonator crystal inside the circuit board need replacement. It will look like this. Replace it with exact frequency marked on it.8_16_2012_4_53_50_pm.jpg
Aug 15, 2012 | Big Button TV Universal Remote
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    Can set up th remote control for this tv with the direct tv cable remote
    Here's how to scan for TV codes on your DIRECTV remote
    1.Make sure your TV is turned on.
    2.Slide the mode switch at top of remote to "TV".
    3.Press and hold the MUTE button. This is located above the number 1 button.
    4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5.Then enter 991, the green light on remote should flash twice.
    5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
    6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    *If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
    7.When the TV powers off, press and release the SELECT button.
    *Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
    Mar 05, 2011 | Curtis LCD2425A TV
    Need rca crk17sa users guide for codes for Magnavox TV
    Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
    http://www.directv.com/DTVAPP/content/remote_codes
    Here's how to program your DIRECTV remote control:
    1. Press MENU on remote.
    2. Select "Parental, Favs and Setup"
    3. Select "System Setup"
    4. Select "Remote"
    5. Select "Program Remote"
    1. Look up the control codes for your DIRECTV remote control.
    2. Make sure your TV is turned on.
    3. Slide the mode switch at top of remote to "TV".
    4. Press and hold the MUTE button. This is located above the number 1 button.
    5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
    6. Enter the first TV code you have. The green light on remote should flash twice.
    7. Aim remote at TV and press PWR button once. The TV should power off.
    8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
    If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
    1. Make sure your TV is turned on.
    2. Slide the mode switch at top of remote to "TV".
    3. Press and hold the MUTE button. This is located above the number 1 button.
    4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5. Then enter 991, the green light on remote should flash twice.
    6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    7. When the TV powers off, press and release the SELECT button.
    Mar 08, 2010 | Televison & Video
    TV does note respond to remote. Volume and menu flashes on screen
    interference from flourecent lights, maybe the front panel buttons are stuck.
    Aug 30, 2009 | Philips 32PFL6704D 32 in. LCD TV
    My RCA 32 ' SDTV TrueFlat doesn't come on
    sounds like you have the parental lock on to lock the buttons on the tv and the remote look in your manual for the tv to see how to fix it and if you dont have it there should be one online
    Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
    Mar 16, 2009 | LG 42LC7D-UB Television
    Wii
    (1)
    Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
    (2)
    Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
    (3)
    Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
    If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
    On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
    Jun 22, 2008 | Nintendo Wii Console
    Televison & Video Logo
    18 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
