Question about Lexmark 4512-220 - Lex E250d Laser Printer
I have a Lex E250d printer, would like to install.
Lexmark E250d - have just installed new cartridge & now won't print. ! light & toner light are both steady orange.
Define "won't print".
Does your computer show the printer as attached, and "online" or "offline" ?
When you try to print a "test" page, do you get an error-message? Exactly what?
Dec 15, 2010 | Lexmark E250d Laser Printer
Lexmark E250d have an amber light in the middle led panel
1 of ur cartiradge has not detected try to replace it 1 by 1 and revert back to me
Jun 18, 2010 | Lexmark E250d Laser Printer
Lex x1150 does not install in new win 7 why
Heres the trick to it. You download the version you need 32 bit or 64 bit save the download.
next locate your download right click it choose properties click on the compatibility tab.
there is a choice to run it in compatibility mode check the box and select your operating system.
next you need to check the option to run as an administrator witch is at the bottom of the
compatability tab apply these options and hit ok.
finaly you will right click it and choose run as administrator wait for the installer to start and follow the promts. and you can use your printer. If your printer is hosted off another computer make sure the workgroup is the same so that windows 7 can find your printer. Search and add the printer your done
Jan 02, 2010 | Lexmark X1150 All-In-One InkJet Printer
I need the set up file of my printer lexmark e250d
from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then ifyou get in troubles, followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Nov 25, 2009 | Lexmark E250d Laser Printer
Compatible printer driver
go to Lexmark web site for suppport and download the driver for your unit...it is free
Nov 08, 2009 | Lexmark E250d Laser Printer
Light keeps fashing for cartridge
Here is something to try:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
Sep 29, 2009 | Lexmark E250d Laser Printer
Trying to install Lexmark E250d mono laser printer
if you are not able to fine the drivers then try the following link
http://www.driversdown.com
May 27, 2008 | Lexmark Office Equipment & Supplies
Lexmark 4512-220 - Lex E250d Laser Printer Logo
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
