Question about Elite Televison & Video
Kenmore elite freezer does not freeze and ice maker does not make ice
Model 795.7103
    Sergeant:
  • 313 Answers
Fill gas in it...
Posted on May 16, 2019
SOURCE:
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
huuum
  • 750 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Posted on Oct 12, 2008
  • 11 Answers
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Posted on Mar 16, 2009
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
I need to defrost fan in the freezer. foe kenmore elite model # 795,72063,111 ice maker in fridge door
I have a Kenmore Side by side Refrigerator grab n go style door Model # 72063. The refrigerator is cold but the freezer is not freezing. Ice maker isn't making ice either. Could anyone tell me the part number for the compressor start relay? Thanks!
Aug 05, 2013 | Dryers
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer won't freeze
remove rear panel in freezer and see if ice an frost is there. if so defrost heater is kaput or the contollers for it.
May 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control pad reads ER IF
er if means the ice fan is not running. it blows freezing air into the ice maker compartment from the freezer. unplug the refer for 24. these are susceptible to frost or ice forming in the blade of the fan and prevents it from spinning. unplugging it will let it thaw. ice is a big problem with this model.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Televison & Video Logo
22 people viewed this question
Top Elite Televison & Video Experts
Akbar Mughal
Akbar Mughal
 steve
steve
Are you an Elite Televison and Video Expert? Answer questions, earn points and help others
