Question about Canon ZR200 Mini DV Digital Camcorder
Cannot view tape playback.
My ZR200 has been around the world and over most of US and Canada. Now, I cannot view the tape thru the viewfinder or the side screen. You can hear the motor "reving". It reves up and then winds down, a flash appears across the screen and then blue background. Then "revs" up, flash, then winds down. Any suggestions?
  • 3 more comments
  • JJY7878 Dec 27, 2007
    My Canon ZR200 wont play back...I get gray lines across the screen. It seems like it is recording fine but when you play it back it dispalays gray lines through the screen...I tried to use a cleaning tape but it did not solve the problem. Any help is great...Should I just toss it and buy a new one? Thanks J.
  • ypick Jan 06, 2008
    My ZR-200 will not play Mini DVs. The servo motor winds up when play is pressed and winds down ( viewer screen dims when the motor is winding down).
  • rg416 Feb 01, 2008
    Same problem here. No grey lines. But I get a blue screen, the tape rewinds, forward, plays but no picture just blue screen only. However when I use the SD card. Everything is working. Weird
    rg416@hotmail.com
  • ronniegirl Feb 21, 2008
    I am experiencing the exact same problem. Do the cassette heads need to be cleaned or something? I am very disturbed by this problem as my camcorder is rarely used and I have only had it a year. Please help. These things are too expensive to stop working after one year.
  • singsongsang Mar 03, 2008
    Same thing. Need serious help with this issue because i need for a video project for school.
I emailed my problem to Canon and this is what they sent me.
"As a first step towards resolving your issue, we suggest that you
restore the camera's default settings. You can reset all of the menu
and button operation settings to default except for Date/Time, Language,
and Video System. To reset these settings, please follow these steps:
1. Please remove the AC adapter and main battery.
2. Please remove the backup battery. It is located behind the main
battery.
3. Please turn the POWER SWITCH to camera, then to PLAY/VCR.
4. Then please turn the camera off for approximately 1 minute.
5. Please use a clean pencil eraser to rub the contacts inside the
battery compartment and on the battery.
6. Put both batteries back on the camera.
7. Connect the camcorder to AC adapter.
8. Clean the tape compartment with a dry tape head cleaner.
If the error is not cleared, we recommend you please send the camcorder
in for service."
You might have to do it twice and put a tape to try and record before it works perfectly. It worked for me so hopefully it works for you.
Posted on Mar 05, 2008
    Habit-Forming:
  • 84 Answers
I just had the same exact problem, and I am going on a vacation tomorrow! Too late to take it to a camera shop so I tried the battery tricks-no luck. Fixed the problem by closing the camera up, turned it off, and (lightly) slammed it on the table twice. Works for now. If it acts up again I'll slam it again. Figure there is a loose cable/connector inside the camera that needs some attitude adjusting so that's what I'll give it. If I break the camera, then I'll get a new camera(probably different brand).
Posted on Jul 06, 2009
This happened to me. half my screen was gray bars. all i did to fix this was to keep watching the video. try FFing it or RWing it a bit while watching. Its creazy, but the bars eventually went away.
Posted on Jan 21, 2009
My problem fixed when i replaced with a bigger longer lasting battery. Your solution #1 posted sounds good thought. Although I didn't try it, since it fixed replacing main battery.
We need to file a major complaint with Canon about this Gray lines problem because it seems like everyone having the same problem! email jphan916@aol.com and I will contact Canon about this issue. Maybe if I get enough complaint they will do some rebate or free repair..who knows, worth a try.
Posted on Jan 02, 2008
Recording playback has lines through it.
try with head cleaner tape 2 or 3 times mostly it works if not change video head assembly
May 24, 2010 | Canon ZR200 Mini DV Digital Camcorder
Gray bars during playback. sound comes in and out
Fast forward or insert another tape. Then record something for 15-30 seconds. Then try your playback again. Worked for us.
Feb 05, 2010 | Canon ZR200 Mini DV Digital Camcorder
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Thanks.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
No images
What is the model number of Canon camcorder?
There are few models of Canon that got ccd imager problem and Canon offers free of cost repair of it.
Aug 09, 2009 | Canon Video Cameras
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
8mm Samsung camcorder: choppy playback
This seems like a tape playback problem. Can you look at the output of the tape in the camera directly into a monitor? And checking the tapes on another machine would also be good.
The fast movement breakup can be something in the playback circuitry of the camera. It may not show up in the viewfinder. Also yo umay try repacking the tape. Fast forward it to the end and rewind it all the way.
Oct 03, 2008 | Video Cameras
Wont accept DV tape..
i have the same problem, but i did nothing wrong to prompt this problem at all. It was sitting on my desk, it worked, then it didn't. go here.... http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=11004&keycode=2112&id=14483
Dec 30, 2006 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
459 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
