Question about Comfort Zone Heating & Cooling
My comfort zone heater model cz1500 turns on alright but unit doesn't heat up.
I can adjust the temp settings either up or down and will hear the 'click' but it doesn't start to heat up possible bad heater element
    Top Expert:
  • Comfort Zone Master
  • 10,321 Answers
Make sure unit has heat strip option if ok possible bad heat element
Posted on Oct 10, 2019
SOURCE:
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Posted on Dec 06, 2008
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
SOURCE: settings on my CZ 1500
To switch between C and F, hold DOWN and ENTER for three seconds.
( I sell these. )
Posted on Apr 26, 2009
  • 4736 Answers
SOURCE: The Holmes Comfort Temp ceramic heater works fine
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Posted on Jan 19, 2011
luxfargo
  • 14 Answers
SOURCE: i need 2 heating elemements
You can order them from True Green 800-595-9605
Posted on Dec 03, 2011
Where can i order a new board for my comfort zone cz1500 the board is bad showing aos code.
It's probably some swolen electrolytic capacitors that need replacing. If you know of an electronic shop close by or buddy that can solder maybe you can remove the pcb and take it to them. Radio Shack may stock the caps.
Jan 15, 2015 | Comfort Zone CZ1500WC Infra-Red...
My heater is not heating I have set all the temps went through all the trouble shouting..it will turn on start to heat then heat shuts off but display remains on??
Your heater may be heading toward complete failure of the heating element but the temperature control thermostat could be faulty.
Nov 05, 2013 | Comfort Zone CZ9009 Oil Filled Electric...
I have a Comfort Zone cz20110 and I need help. The heater will turn on and blow out heat, but the display screen is blank. It was not blank when we first plugged it in however and I know there's a way...
i have a digital quartz infrared heater comfort zone cz20110. does the fan keep running all the time and when it reaches the temp to your room why doesn't it it shut off.
Jan 02, 2013 | Heating & Cooling
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
Settings on my CZ 1500
( I sell these. )
Mar 11, 2009 | Comfort Zone NEW 09 Electric Portable...
Heating & Cooling Logo
Top Comfort Zone Heating & Cooling Experts
Marvin
Marvin
Paul Carew
Raymond Richards
Raymond Richards
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
