Detergent slot codes. What do the stand for. 1st time washing
I have a fisher & paykel front loading washing machine & need to know what each of the three slots where washing powder goes stand for? Machine Product Code 98707 & numbers WH70F60W1
You normally have 3 cups; 1 for Bleach, 1 for Liquid Fabric Softener, and 1 Liquid Clothes Detergent. I don't ever recommend using Laundry powder in front loads as it has a tendency to not fully dissolve and will build up in the dispenser overtime and prevent your clothes from washing.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 12, 2018 | Fisher Washing Machines
Servis wp1249f2w leaving powder in the drawer each time, any solutions?
Stop using powder. Use liquid instead and see if that makes a difference.
First off. Before changing the detergent clean the residue of the powder from the tray.
Another thing to keep in mind is the type of detergent.
You want HE detergent. The reason for HE is it uses less and leaves nothing behind. ( HE stands for High Efficiency detergent.)
Hope this helped.
Mar 09, 2015 | Washing Machines
Whirlpool duet f28 code
Turn off the power. Remove the detergent tray. Reach in the slot where the detergent tray fits and look for a lever. Pull it and replace the detergent tray. Turn power on. Good luck.
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing code f 28
duet washer flashes F20 and stops. Any help?
Oct 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F28
Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
Oct 05, 2009 | Whirlpool Washing Machines
Hi, I'm house sitting for a friend and he has a kenmore elite washing machine. Which slot do i put the liquid clothing detergent in? softener? or
The LEFT slot is for detergent. Do not overfill, or you may experience a "SUDS" error. It is recommended that only HE detergent is used. The RIGHT front slot is where you put the fabric softener. Again, only fill to the fill line.
These washers are engineered to use very little water, so you only need a little detergent. If you have questions, please let me know. I hope this helps you.
Sep 03, 2009 | Kenmore Elite 45986 Front Load Washer
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
