Question about LG Washing Machines
Door locked LG LMC1543SS - LG Washing Machines
Lg washer wm2455hw door won't lock. DE code flashes.
LG Washer Door or Lid Won't Lock - Model WM2455HW ...
www.repairclinic.com/...Washing-Machine/...-/LG-Washer-door-or-lid-...
LG washer door or lid won't lock? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Nov 15, 2015 | LG Washing Machines
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
My door on my LG front load washer will not lock.
make sure there is no debri in door locking mechanism/ also check wires to switch and at the ccu or the actual control board on unit...lg. is known for loose wires and creating problems... if that does not do the trick then most likely you door lock has went out and ...
Jan 05, 2011 | LG WM-2277HW Front Load Washer
Model lmc1543ss. Handle snapped and broke can I get a new one
Jus wondering if you had any luck finding this handle? We need one too.
Sep 21, 2010 | LG Microwave Ovens
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
My lg front loading washing machine does not start
sounds like you have a faulty door lock and it will not turn on if it cannot lock, you will need to get it replaced. Look around at different repair shops as some charge more than others
Jan 14, 2009 | LG WM-2277HW Front Load Washer
Door doesnot close
The LG LDS 5811 and all models that start with 'LDF" do not have a door latch. They do have a child lock _but_ that feature does not lock the door closed or open, it just locks the controls so the DW can not be turned on or settings changed.
So, please look at the right side edge of the opened door and post the model # back here.
Thanks!
Aug 14, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
22 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
