Hi has anyone fixed the E02 fault code (water flow) by removing the sensor and just twisting the cables together to make a connection?
    Master:
  • 732 Answers
It seems the by shorting the wires together, the processor will always sense watetflow, even when there should not be any, then trigger a new alarm for waterfowl issues.
Posted on May 15, 2019
SOURCE:
  • 18 Answers
SOURCE: E02 Code
Faulty heating element, or main eprom is faulty
Posted on Jul 12, 2007
  • 188 Answers
SOURCE: water over flows think its the water sensor
It's likely just the hose to the pressure (water level) switch that has come loose or fallen off. Remove the console screws and flip back the console to get access to the pressure switch and the connections. If the connection end of the pressure switch hose looks "stretched", trim 1/4" off and re-seat it.
If the hose looks ok (no cracks or splits), check the other end of the hose which connects to the side of the tub.
The see if the pressure switch is faulty, remove the pressure switch hose and attach a small hose to the pressure switch. Blow into it gently and listen for "clicking". Test with a fill to see if the switch shuts off the water valve.
Let me know if you need more assistance. If so, please post your model number.
Posted on Apr 08, 2009
seanpwright
  • 2030 Answers
SOURCE: Hi I have a fault code P1180 Linear O2 sensor /
Yes you have a problem with wiring for the O2 sensor shorting out somewhere in the line. It could be anywhere from the sensor to the ECU. Make sure there are no breaks, burns, or crushed parts of the wiring.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Feb 02, 2010
adamh294
  • 310 Answers
SOURCE: lay z spa pump has
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Posted on Apr 27, 2011
taran_2005
  • 10515 Answers
SOURCE: I have an E02 Code
E02 means the unit is not getting adequate water or the drain is coming clogged. Remove the round access panel on the lower right front panel and take the drain catch off by twisting it. Water will come out so be careful, remove and clear all the debris in the drain catch. If you don't find anything then the issue might be with lack of water getting into the unit. If you are sure the water hoses are not frozen and have good water pressure then you will need to replace your electronic water valve on the back of the washer.If that doesn't resolve the problem and still shows E02 and you could hear pump running while filling,you have a closed relay on the board that should be open until it gets to the drain cycle.Something has happened to the board you are going to have to replace it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 05, 2011
Bosch washer giving E02 error, drum has excessive water in it, takes 3 manual drain cycles to empty drum
E02 error code is either water supply side not enough (kinked hose) or more likely in your case clogged drain [hose] or particle filter.
Dec 10, 2017 | Bosch Washing Machines
Hy, I have a washmasine bosch WAE28267SN that sow me an error E02 that's the error. Somebody can help me with some tips Thanks
The E02 error means that the washer is slow to fill. This can be caused by a problem with the incoming water hoses, the water valves or the washer draining as it fills.
The first thing to check is the incoming water if you have very little water in the washer. Make sure that the shut-off valves have been opened fully. If they were fully open, close them. If they were closed, check if that solves your E02 problem. Next remove the water hoses. A damaged anti-flood hose can reduce the water flow to a trickle. Clean the filters at both the shut-off valves and the intake valve on the washer. Replace the hoses at the shut-off valves. With a bucket below the hoses, turn on the shut-off valves and check that you are getting good flow. Now, attach the hoses to the washer. Check if the washer fills properly.
Check that the drain hose is positioned so that the outlet is above the water line of the washer. If your E02 issue continues and no water gets into the machine, then the inlet valve could be stuck in the closed position. If the washer is filling and the E02 error persists, then the water flow sensor may be a problem. This sensor has air tubes that can become clogged. Make sure that they have no dirt. There are other parts in this sensor that could be damaged.
Unfortunately, I don't have a source for parts for this washer. Some Bosch water inlet valves are available here: http://www.appliancepartspros.com/bosch-washer-valve.html . If your washer is under warranty, contact Bosch.
I hope this helps.
Jun 15, 2016 | Bosch Washing Machines
How can I delete E02?
Depends on the make and model but an Error code E02 on most washing machines is slow water flow probably caused by a blocked filter! Remove panel on front bottom left or right side and clean filter! Should then clear error itself!
Oct 21, 2014 | Washing Machines
Siemens faults
Assuming the inlet valve and hose and supply is OK and its filling with water....e14 is..
Flow fault or flow sensor fault, could be a poor connection on the sensor to the water matrix or less likely a blockage in the matrix.
Also check all inner for cleanliness and debris.
Aug 06, 2014 | Dishwashers
Heater has been running and heating, but getting E02 error and HI
sounds like a water flow issue check your bypass valves check for clogged filter or thermal regulator ,or manifold bypass
May 17, 2014 | Pentair Minimax NT Heater
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
Apr 27, 2011 | Pool & Spa
Replacing bad camshaft position sensor
  1. Disconnect battery ground cable.
  2. Remove water pump pulley attaching bolts, then the serpentine belt and water pump pulley.
  3. Disconnect sensor wiring connector and remove sensor retaining bolt.
  4. Twist and pull sensor to remove.
Reverse procedure to install and prior to installing new sensor, lubricate sensor O-ring.
It is located under the water pump. Make sure when you remove the sensor that you rotate the crank shaft and look in the hole to make sure the pick up magnet is still in there. Sometimes they come loose and cause a no start or long crank. You will need to have the code cleared still.
May 06, 2009 | 1991 Pontiac Bonneville
Whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
E02 Code
Jun 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
