Error code 08 , what is this fault ?? - Washing Machines
2 Suggested Answers
SOURCE:
  • 86 Answers
SOURCE: error code F-08
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think you will find the pump comes on because the heater relay is stuck which then gives out the error F08, not the other way round. Check the heater, the pressure switch and the module connections (you will need a multi meter of some description) to check the connections.
Posted on Jul 09, 2009
Ideal icos 18 fault code HF
According to pages 47-50 of the install guide, section on FAULT FINDING, the alternating H and F indicates Flame Detection Short Circuit Error. Actions are: Remove flame detection electrode terminal from PCB. Test for continuity between 2 terminal pins? If YES, replace flame detection electrode. If NO, replace PCB. If you need more diagrams and full guide go to http://idealboilers.com/installer/wp-content/uploads/sites/2/2013/08/203318_inst.pdf
May 19, 2014 | Water Heaters
Fault code Pn 68920-07
Hi Anonymous, these are not fault codes they are part numbers for the speedometer and tachometer currently installed on your bike and for more information on your question please visit the websites below and good luck: Harley Davidson Sportster error codes and how to access them
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 17, 2013 | 2006 Harley Davidson XL 1200 C Sportster...
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
I have a hotpoint WT940 error code f-08 has appeared, what does this mean
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
Oct 14, 2012 | Washing Machines
Hotpoint ultimate wd860
First all all unplug it for 2 mins to clear error code. That error relates to heater or pcb fault. Check the wires on the heater then pcb make sure they are tight. Give the relays a tap on the pcb it could be stuck
Apr 25, 2012 | Hotpoint Washing Machines
I need the error codes for a Yamaha R1 2008
Hi, Swart_marie for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/105-07-08-r1-mechanical-help/260979-error-code-15-07-08-r1.html
Yamaha Fault Codes motorcycle manuals
http://www.lethaladrenalinrydaz.com/index.php/service-manuals/finish/3-service-manuals/6-2007-2008-yamaha-r1-service-manual/0
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Feb 27, 2012 | 2008 Yamaha YZF-R1
Code error 08 what does that mean
Although you have not said what the model is, in my lists of different Hoover models for most 'error 08' indicates a 'tacho fault (motor speed)'. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 19, 2011 | Hoover Washing Machines
Showing error code F-08
We let the washer stand for 45 mins then tried to wash again and it washed another 3 times and has not shown the fault since.It is the relay for controlling the heating element and tends to stick when it gets warm.We found that letting it cool for a while and resetting itself it worked again.This might not solve the problem in the long term but it worked for now.The fault shown was F-08
Thank you
Jun 16, 2009 | Hotpoint Ultima WD72 Front Load...
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
