Question about Whirlpool Washing Machines
The whirlpool cabrio has water trapped in the liner,how i drain that
The drum and liner are out of the cabinet machine now, but the water still are there; please the water has to be there o how can i drain it;on the botton of the liner i can see 5 hold sealed with a hard round plastic; look like was fill with water and after was sill; thatis thru?
SOURCE:
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
mosescape
  • 3 Answers
SOURCE: Hotpoint WMA35 - water will not empty and will not spin
Hi Debbie
Yes your machine will not spin if the water cannot drain... I do not have the machine in front of me but I would presume to think that you have a blockage in the water pump (or drain pump)
There is a normally a small pvc or plastic filter just before the pump and this would stop most big things entering the pump.. if not there could be a coin or button stuck in your pumps impeller.
Unfortunately if you are not technically inclined you will find it hard to access and open the pump otherwise just open the back plate on the machine (after removing the power socket from the wall) the pump is located at the bottom left and fairly easy to remove and open the plastic casing.
If this does not solve your problem please give more info........
Posted on Feb 20, 2008
  • 240 Answers
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Posted on Mar 14, 2009
SOURCE: shirt caught between the drums on my whirlpool cabrio washer
1. Unplug and take off the top of the washer.  There are two pressure clips in the front inside the crack between the top and body of the washer.  Use a stiff putty kniff to depress the clips and flip the top up out of the way.
2. Pry the top plastic shroud off the tub.  There are a series of plastic retainers clips around the shroud.  Pry them up and remove the shroud.
3. On the small agitator on the bottom of the washer, use your putty knife to remove the domed plastic cap in the center.  Pry it up with the corner of the knife to expose the nut.
4. Use a socket wrench to remove the center nut.  It will likely take a good deal of force to loosen it.
5. Once you have removed the center nut, get another person to help you lift the stainless steel inner tub out of the washer.  Place it aside.
6. In the bottom of the outer plastic tub, you will find the shirt (or other garment) caught in the drain.  Remove the screws on the top of the plastic drain cover, and lift up the drain cover.
7. Remove the stuck item(s).  For all the coins and small part that have fallen into the drain tub, you may have to open up the back of the washer and remove the drain hose to access the items in the drain.  Luckily the drain hose is held on with cheap hose pressure clamps, so you can do this relatively easily.
8. Call or email whirlpool and tell them that the washer is pulling clothes into the space between the inner and outer drums.  They will respond by telling you they have never heard of this problem before and if you need service, call "A&E Factory Service toll-free at (800) 771-3029."
9. Be frustrated and vow never to buy a Whirlpool product again.
Hope this helps
Posted on May 05, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Whirlpool Cabrio Platinum is over filling the detergent, bleach and fabric softener dispensers, with great pressure.
sounds like you have a bad water valve on the washer,go to the searspartsdirect.com ,put in your model number and look up the valve.next time send the model number for anything you're having a problem with
Sep 14, 2017 | Whirlpool Wtw8800yw Cabrio Series 4.6 cu....
My whirlpool cabrio has water trapped in the wash basket. Is this normal? Keep getting UL code and checked everything else.
I have the same issue. when I remove the wash basket from the tub the plastic parts all seem to have a lot of water trapped inside them. I am looking for a solution and may start my own question. not getting any fault code at all the washer runs as designed. but the dirty water trapped in the plastic top of and bottom of the wash basket is making the clean clothes smell like a dirty dish rag.
Sep 05, 2012 | Whirlpool WTW6400SW Cabrio Washer
LD error on the Whirlpool Cabrio Washer. We are trying to remove the drum to remove items
Hi
Ld error indicates long drain and flashes when the water level will not change even after the drain pump is on. To resolve this please make sure that the drain hose is not clogged and the pump is working. To gain access to the drain pump you can lay the machine on its front then remove the drain hose and replace the pump if the impeller has gone bad. Please post a comment if need more help.
Thanks
Rylee
Oct 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
my cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Aug 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW5520SQ0, when draining the water is coming out at such a fast rate it's backing out of pipe and on the floor.
For many of the new washers you need to have a 2" standpipe and trap... the older 1-1/2" standpipes and traps will not handle the higher volume of the new pumps...
heatman101
May 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer has ld code. have checked pump as well as inside the washer by taking basket out & nothing is plugged up. there was a small amount of water in drum when we removed basket....
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
Oct 20, 2009 | Whirlpool Washing Machines
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Washing Machines Logo
27 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
