Question about LG Washing Machines
My LG Wave Force washer will not agitate!!!!!
4 Suggested Answers
SOURCE:
SOURCE: GE Profile top load washer - Agitator rotates very slowly with li
Agitator coupling is worn out. Replace coupling underneath the agitator (WH43X10032)
Posted on Oct 14, 2009
  • 311 Answers
SOURCE: Does this smelly mold problem just apply to the
Any front load will have odor issues if you don't leave the door open and dry off the door gasket.
Posted on May 28, 2010
  • 164 Answers
SOURCE: Lg wave force washer want come on and door is locked on top of washer
Did you check to make sure power is coming from socket?
Posted on Aug 14, 2018
Getting agitator auger off agitator on whirlpool LSN1000JQQ0 washer
Remove the plastic cap on the top of the agitator that covers the retaining nut and unbolt it, it will be rusted and take a lot of force to remove from the drive splines. Here is a link to a video. How to Remove the Agitator From Top Loading Washing Machine
Aug 30, 2018 | Whirlpool Washing Machines
Aug 14, 2018 | LG Washing Machines
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
Washer not agitating properly.
Try looking under it as I've had that problem and found it was build up of dust
Jul 11, 2015 | Kenmore Washing Machines
Need to know where filter is on the Lg top load wave force washer
Many times the hose gets mushy and either fractures or leaks from a weak point on the hose. In some cases the hose attachment leaks at the connecting point as the clamp is loose or the hose shrinks around the fitting.
Apr 15, 2014 | LG Washing Machines
I have a LG wave force top loader and I have a mold smell that doesn't go away. I have run the tub clean mode a few time, usually adding bleach to where you would normally add bleach. However I...
I have the same model washer and also have that gross mold smell. However, it has NOTHING to do with liquid fabric softener because I ONLY use dryer sheets.
May 02, 2012 | LG Washing Machines
GE Profile Washer Agitator will not come off
there is a product called agitamer, a rubber bladder inserted under agitator and hooked to your cold water line, pressure popos it off quite nicely
Feb 22, 2008 | Washing Machines
Getting the agitator out
there is no screw or bolt holding it in. its just a matter of getting enough upward force on it to get it out. you need to pull straight up from the bottom. some times a rope under the agitator helps.
Nov 26, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
