Question about LG Heating & Cooling
What is the meaning of this LG Aircondioner error code CH 38 ,and how do i solve it..ur help is urgently needed
SOURCE:
  • 4 Answers
SOURCE: ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Posted on Jan 20, 2009
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
  • 234 Answers
SOURCE: LG error CH 64
What is the model of the unit?
Posted on Apr 07, 2009
  • 400 Answers
SOURCE: lg ductless air conditioner is coming up with code ch 5
Communication between indoor PC and outdoor PC missed. Check that all connecting cables are good.
Posted on May 08, 2009
  • 109 Answers
SOURCE: if 5+3=28, 9+1=810, 8+6=214, 5+4=19, 38+20=1858
Hi 5+3=28, 9+1=810, 8+6=214, 5+4=19, 38+20=1858
First find difference and then sum............. If we take 5+3 =28, 5-3=2 and 5+3=8 so answer is 28 like wise
7+3 = 410 So answer is 410
Posted on Jul 17, 2010
Our LG air conditioner is show code CH 01. What does this mean and what's the fix?
The E2 / CH01 error code is an AUTO-STOP PROTECTION error resulting from a short or open circuit in the indoor pipe sensor. The unit will require a repair service. Airbulance AC Repair is always here to help.
Jul 02, 2018 | LG Heating & Cooling
Tip
Error code CH-04
In LG multi split/cassette type units, error code ch-04 means Float switch Open circuit (High level water alarm). Dis assemble the indoor and clean drain pan.
on Jan 11, 2011 | Heating & Cooling
Error Code 38 on my LG Split Air Conditioner.
I call LG Mexico and they told me a Gas Leak.
Called in the Gas Guy, filled with new Gas and fixed the leak, now the AC works again. Nice.
Jan 21, 2018 | LG Heating & Cooling
Have a LG split air conditioner Model # LS243HLV getting error code CH 38
Please give model numbers of both indoor and outdoor units!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 21, 2017 | LG Heating & Cooling
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
Hi, When I tried to start my dehumidifier, it won't work and indicate CH 01. The bucket is totally empty and in good place. What this CH 01 means?
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
Apr 14, 2011 | LG LHD45EL Dehumidifier
Ch 5 error code
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Heating & Cooling Logo
59 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
