Question about GE Microwave Ovens
I have a GE microwave model number JES2251SJ 02, the microwave runs for 3seconds then shuts off. You set it again it runs for 3 sec and turns off, basically can do this all day. I ha e reset the microwave and it still does it. Fuse can't be blown or we wldn't be able to keep running it for 3 secs. Any help would be greatly appreciated.
SOURCE:
Teckies
  • 226 Answers
SOURCE: ge microwave
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problerm on the control circuit board1.gif.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Jan 24, 2008
AlmostBob
  • 550 Answers
SOURCE: fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Posted on Oct 14, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: microwave runs 3 sec then shuts off.
mtystufquit - We've already discussed this by chat & e-mail, and if and when you need further help, please let me know.
"If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle."
ddmdavid - you probably have a bad door switch or door switch mount. Please see these links.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If you still need help, please create a new post with your brand and model number.
Posted on Dec 15, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: GE Microwave shuts off after running 3 seconds
It is a loose or bad magnetron emitting electrical interference that disrupts the control unit.
When you move the circuit board away from the magnetron or take the cover off, the interference is weakened, and the control unit works fine.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the mag warranty, G.E. should send you the magnetron to do it yourself. Call them at 888-239-6832 with your model, serial, and manufacturing date.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer.
Posted on Mar 02, 2009
  • 9 Answers
SOURCE: Emerson Microwave Model MW8119SB found blown
Chances are that either the diode or capacitor are shorted. Be very careful, the capacitor can store a charge and should be discharged first for safety. Hope that helps...
Geno
Posted on Dec 06, 2009
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
Microwave turntable does not work
lt is either the safety switch which if bad would prevent heating or a problem with the motor or gear system used to turn the table.
Dec 21, 2012 | GE JES2251SJ Microwave Oven
Microwave timer is locked. how do i unlock it?
Press/hold the clear/off button for 3-5 seconds.
Thanks!
Sep 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs however it is not heating. I replaced Magnetron and it still doesnt heat. As I was replacing it I noticed a little debris around the HV Capacitor. When I turned it on there was smoke...
Not sure if they will or not. The magnetron is a fairly simple replacement. Soldering does take some skill and can easily ruin a control board if you do not know how to removed and replace components. If you know how to solder, just read the information off of the capacitor then search online for a direct replacement. More than likely it would be cheaper that way then getting it from GE (if they sell them).
Nov 29, 2017 | GE JES2251SJ Microwave Oven
Microwave shuts off after running for five minutes
I'd be careful because you do not know what caused it to spark. How old is the microwave? Do you need a new one?
Jun 14, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
Sep 21, 2017 | GE XL1800 1100 Watts Microwave Oven
GE Mircowave JES2251SJ -
The internal magnetron cooling fan is located behind the control panel assembly.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Nov 29, 2008 | GE JVM2050 Microwave Oven
Shuts off
change your electrical wall plug to a diffferent one, do not use extention wire pls, there is insufficient to drive your microwave, thats why it resets and restarts again
cheers
Nov 25, 2008 | GE JVM2070 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
