Question about Technics SL-DZ1200 Turntable
BaD SouND its being like 5 or 6 months that my turntable doesn't sound like it should be...every time that the wheel is going around the sound is distorted :S can anyb0dy Help please?
  • DjCo0L Nov 28, 2007
    the distorted sound is kind of scratch always in the same point when the track plays..anyway i think what i need is a qualified service center to repair the unit and if is n0t t0o much 4 u i would like to kn0w wich place i should go in London to go with the turntable. thanks a lot!
  • 515 Answers
Do you have the unit in Turntable mode? Can you describe the distorted sound? Is it a hum, sound cuts in/out, scratchy sound? There have been alot of issues which plagued this unit. We get at least 1-2 a week in here for various issues. Although, I've never had one with distorted sound, that wasn't caused by something else (bad RCA cables, faulty mixer line, etc).
So make sure it is the unit. If so, you will need to take this in to a qualified service center for repair as determining the issue requires the tech run some test on the unit.
Posted on Nov 27, 2007
    TERMiNAL OPTiC Nov 28, 2007
    We are based in NY, so I can't really refer you to anyone in London. However, you can call Panasonic UK, which is the parent company of Technics, and they can refer you to a local area service center. - go to the support section.
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Humming sound at around RPM level 2 car
this could be a bad wheel bearing.
May 21, 2013 | 2005 Audi A4
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Aug 17, 2011 | Audio Players & Recorders
Numark Omni control-iMac Problems
Did you try this turn table on another PC? It is the best way to check for I never seen a NuMark act like yours. A secondary PC is always great to have if you constantly need this turntable
Mar 28, 2010 | Numark ttUSB Turntable
Phono plays lower in volume than cd and tuner. Sounds ok i guess but is about a quarter to one third lower in volume. Is this normal ? Can I plug phono into cd jacks to check if any better ?
Hello. As per the post before me, if you have a receiver with a Phono input(many receivers don't have one anymore) the output of a phono cartridge is around 30 millivolts, vs 300 millivolts for a CD(10 times the amount) or any other line level device. A Phono preamp, also has RIAA(recording engineering standards)Equalization that provides the proper equalization for a Phono cartridge. As per the other post, yes, it will sound very low, and unnatural sounding. If the input you are plugging the turntable input into, doesn't say Phono, you can purchase an inexpensive Phono preamp made just for this very issue. You can try Radio Shack, or find something of better quality on the Internet.
Jan 11, 2010 | Pioneer VSX-453 Receiver
ION iTTUSB turntable has buzzing sound when I record
It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
Nov 28, 2009 | ION Audio iTTUSB Turntable
The glass dish that goes around - makes a strange noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
You may have a bad motor orplastic coupler.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
Nov 22, 2008 | Kenmore Microwave Ovens
Goldstar 1310W built in
The following parts are in the turntable system: The turntable motor, underneath the floor of the microwave; the turntable coupler, which is like a small plastic piece; the turntable support, either a three-legged or circular piece with wheels; and the glass turntable tray.
It sounds like maybe your turntable support is missing?
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. Goldstar owner manuals can be downloaded here.
Aug 11, 2008 | Goldstar Microwave Ovens
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Technics SL-DZ1200 Turntable Logo
440 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
