Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
On/Off & Start/Cancel buttons stick
When I push either of the two adjacent buttons for On/Off and Start/Cancel on my WD640 Aquarius+ they stay depressed, partially disappearing into the casing on the front panel. I have not been heavy-handed at all - it only takes the slightest pressure to make this happen and itis almost impossible to get the buttons back to their correct position in order to use the machine again. Surely Hotpoint could not have designed these to be so flimsy, could they? Is there anything I can do?
    Champion:
  • 249 Answers
Super glue them in place] close ire
Posted on Nov 28, 2007
Hotpoint aquarius wd640....start/cancel, off on button not pushing in and light flashing f-13
F13 indicates High Dryer Temperature.
Check the dryer motor runs OK and that the fan isn't hanging off. (You'll hear it if it is).
Check the connections to the dryer NTC (temperature sensor on top of dryer)
Check the condenser isn't blocked (under the fan motor, plastic unit going down the rear of the tub).
If all checks out OK, try changing the dryer NTC.
Jun 02, 2011 | Washing Machines
The digital screen is stating H20
This is what I have been told- by a reputable company (!)
If it is not in DEMO mode it means that there is no water being supplied to the machine. If it is in DEMO mode cancel it by pressing and holding the start/cancel button then press again to cancel the drain and the machine should display 'ON' as usual.
Good luck,
John C
Apr 04, 2011 | Hotpoint Aquarius WD640 Front Load...
Switch on it shows "test" and cannot programme
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
John C
Mar 22, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washing machine Aquarius WD640
Try this sequence; Hold down start and cancel button together, TEST should disappear of display,
Then hold down START/ CANCEL, and ON/OFF at the same time.
The message D/off should appear in the display, it should then work.
If it does not then the main pcb is likely to be faulty..
That will mean calling an engineer.
Pleas rate my fixya solution.
Thankyou.
Feb 07, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint wd640 and i cant get it out of test mode any ideas?
trn main dial to empty drum icon
press start/cancel button and on/off button together then switch off at mains and leave for 10 mins
got this info off hotpoint themselves and it works for me
Jan 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpont washer/drier
if you accidently push the on/off and start buttons together, this put the appliance into a test/demo mode. to cancel it you just need to push the on/off and start buttons at the same time and "d off" should be displayed on the screen and it should now work as normal
May 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD645
If you by accident press the start button and the cancel button at the same time it puts the washer into demo mode.To switch it off press both buttons at the same time and hold until dEND is displayed. Sometimes you have to keep trying but it will work, it did with mine ok.
Sep 09, 2006 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
56 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
